P2 manual swap
yan_s333
Hello !
I want to swap my ‘05 S60 T5 from automatic gearbox to m56lk and i know that it doesn’t came from factory with this one but I also know that it should fit.
Need your all help with some tips about what parts I would need for the swap and maybe some suggestions for parts like clutch and other things, or maybe a full list for what i need for a complete swap.
thanks for all your response! :)
Hi
I would use the FWD M66 if you can find one. If you do use the M56 then get the P2 version.
For simplicity sake, I would use the S60R clutch and flywheel, any p2 manual pedals will work. Shifter and cables should match the gearbox. Then you will need the clutch master cly, clutch line. I'm not sure about the axles. You might get away with your original axles since it's fwd. You will also need ECU and CEM flash to manual.
Check on swedespeed on the R forum. A lot of this stuff will be similar and there is a lot of info
