pinky Posted June 27, 2023 Report Posted June 27, 2023 I have an older version of this motor on my "whole house fan" (what most people call an attic fan). The fan started to have a little rattle so I crawled up into attic and found a loose set screw on fan blade assembly. The fan ended up being quieter than ever. So Now I started noticing the slight squeak in belt and the rattle of some of the louvers and who knows what else. I have no started to look into all parts to service. Ordered a new belt. Noticed it says to lube with motor oil, so I guess I will look for oil port/s. Anyway onto my electric question. As it sits now I only have an on/off switch. I ordered a Master flow 2 speed fan control switch BWS2 without thinking. Now that it is here I looked up how to wire it. Seems you need a fan set up for 2 speeds. Well I have no idea if this motor can or is a 2 speed motor????? Thank you https://www.amazon.com/Century-formerly-Smith-GF2054-Bearing/dp/B006P1NRZS/ref=asc_df_B006P1NRZS/?tag=hyprod-20&linkCode=df0&hvadid=198064502357&hvpos=&hvnetw=g&hvrand=8004074314275465058&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9023906&hvtargid=pla-323464538052&th=1 https://www.homedepot.com/p/QuietCool-2-Speed-Control-Switch-IT-35000/206049248
Ol' Dirty Noodle Posted June 28, 2023 Report Posted June 28, 2023 I’m an electrician but the links aren’t working for me
