Dual mass flywheel measurements needed
940 16 valve
Anybody got a used flywheel/clutch assembly off a late model T5/R they could give me measurements off?
I typically frequent Turbobricks since I have a 760, but it's swapped to a 2.5t 5 cylinder so I thought I might have more luck here. Project thread if you're interested:
https://www.turbobricks.com/index.php?threads/760-5-cylinder-scratching-a-10-year-itch.341191/
I'm running a bmw 6 speed trans, with a 850 single mass flywheel. I daily this car and I'm over the gear noise and want to swap to a dual mass, but the input shaft is quite short on the GS6-37 transmissions which are designed for a pilot bearing in the flywheel. Anyways, trying to find the height of an assembly flywheel/clutch/pressure plate assembly to the surface of the pressure plate fingers to see if this is even an option for me. Can anyone help me out?
Thanks!
Not many people left on here, but maybe someone will have a project sitting in the garage that they can take measurements from.
