Sandforce13 Posted June 4, 2024 Report Posted June 4, 2024 Hi, because the eager for more power in my -99 v70xc i have to change the engine. The one i have has past best before. Do88 intercooler, 3” Downpipe installed. Dont know what turbosize i will have. Hx35-40 maby? Changing the rodds and pistonrings in advance. Anything else u recomend? Do i need a oil catch can? How long does the awd stand? And allso, easiest way to engineswap? Up or down? Thanks in advance!
RobT5M Posted June 7, 2024 Report Posted June 7, 2024 On 6/4/2024 at 4:20 AM, Sandforce13 said: Hi, because the eager for more power in my -99 v70xc i have to change the engine. The one i have has past best before. Do88 intercooler, 3” Downpipe installed. Dont know what turbosize i will have. Hx35-40 maby? Changing the rodds and pistonrings in advance. Anything else u recomend? Do i need a oil catch can? How long does the awd stand? And allso, easiest way to engineswap? Up or down? Thanks in advance! Which year do you have? Big difference between 98 and 99 p80s. On the turbo, make sure it will fit or you will likely have to do a custom exhaust manifold. Also think about how you will route water/oil lines. Rod, pistons, is a good idea depending on power goals, obviously if you are already in there doing that, and depending on what engine you decide to go with, do shims as well. Upgrade the fuel pump and injectors, look at e85, and you should look into water/meth injection (kits can be had fairly cheap). Obviously you will want to do tuning, no idea who tunes anymore, there is a good bit of knowledge out there about tuning on motronic now so depending on your knowledge you could do it yourself, maybe. You've likely already thought about exhaust, but take into account stopping power as well as handling.
