850t-5 man Posted April 14, 2004 Report Share Posted April 14, 2004 no since all the manual trannys that we have in the states come out of na cars they should be the same final drive, maybe if you get one out of a c70 it will be different Link to comment Share on other sites More sharing options...
Lmohaxx Posted April 14, 2004 Report Share Posted April 14, 2004 Okay so the M56h.. plus ?? is it a hydraulic or cable trans?Clutch, clutch pedal, shifter, linkages, cable or hydraulic lines (depending), what else is involved? a new ECU?.. thanks,Chris Link to comment Share on other sites More sharing options...
EricF Posted April 14, 2004 Report Share Posted April 14, 2004 Is it possible to merge topics..? Link to comment Share on other sites More sharing options...
ovlovturbo Posted April 15, 2004 Report Share Posted April 15, 2004 the m56h is cable activated with a hydolic clutch set up that runs off the brake res. and as for parts you nes and shifter, the new clutch the drive axles, the flywheel, the pedal assembly, the slave clylinder and the clutch pedal cylinder, new bolts for the flywheel and the cluth, new throw out bearing, and i think that is it for parts, i cant really remember, but thdrenaline who has the full parts list and all the info you needhope this somewhat helps Link to comment Share on other sites More sharing options...
Lmohaxx Posted April 15, 2004 Report Share Posted April 15, 2004 Okay, Great!Thanks a lot, I do appreciate it!Chris Link to comment Share on other sites More sharing options...
volvo850r Posted April 15, 2004 Report Share Posted April 15, 2004 As far as i know you dont have to replace the the drive axles. Link to comment Share on other sites More sharing options...
Lmohaxx Posted April 15, 2004 Report Share Posted April 15, 2004 volvo850r.. could you direct me to where you sourced the parts for your swap?Thanks Link to comment Share on other sites More sharing options...
thedocdm Posted April 15, 2004 Report Share Posted April 15, 2004 I recall a post from a long time ago on this topic, where somebody offered a complete conversion kit, with m56h and all necessary equipment for somewhere around $2000 IIRC? Anybody remember? Link to comment Share on other sites More sharing options...
850 Arrr! Posted April 15, 2004 Report Share Posted April 15, 2004 Does anyone know which model Volvos came with the M56H, and which came with the M56L? The parts guy I am talking to has a complete 1997 850 with an M56, but he does not know if it is an L or H. I figured that if it is complete, I could get all the parts I needed from this car, but I'm not sure if it is the M56H.Anyone know?Thanks! Link to comment Share on other sites More sharing options...
volvo850r Posted April 15, 2004 Report Share Posted April 15, 2004 If its a 97 then it should be an h. Link to comment Share on other sites More sharing options...
ovlovturbo Posted April 15, 2004 Report Share Posted April 15, 2004 bill told me that you had to get the drive axles as well, so i would pm him, bill at adrenaline racing and ask him for the list of parts and so on Link to comment Share on other sites More sharing options...
Lmohaxx Posted April 15, 2004 Report Share Posted April 15, 2004 If anyone gets an official parts list for this swap, please post.Thanks! Link to comment Share on other sites More sharing options...
Bill at Adrenaline Racing Posted April 15, 2004 Report Share Posted April 15, 2004 M56H is from 1996+ cars. The M56L is from -95. I am told by many racers in Sweden to go with the H. I did and it is good. Parts needed are:M56H transmission"R" clutch disc, pressure plate and throw out bearing.Flywheel from a -98 car that has been machined flat and true again. Shifter assembly with cables.Hydaulic slave cylinder/line from the clutch pedal to the bell housing.(one piece)The clutch pedal/brake pedal combination unit.(one piece)The clips to hold the clutch line to the pedal.The bolt that attaches the slave to the firewall for clutch. There is a knockout already in the fire wall. You will need to loosen the booster though to slide it in.The slave cylinder on the bell housing to actuate the clutch fork. Clutch fork if it is not included with the tranny.Axles from the manual. Synthetic Volvo fluid. I will post some directions later.Regards Link to comment Share on other sites More sharing options...
850 Arrr! Posted April 16, 2004 Report Share Posted April 16, 2004 Thanks, Bill! You are my hero! :lol: Link to comment Share on other sites More sharing options...
s15det Posted June 21, 2004 Report Share Posted June 21, 2004 Thanks, Bill, for this list. I noticed at FCP Groton, that they have different part numbers for the manual axles for a turbo, and the manual axles for the N/A. I, too, have found a 850 N/A in a salvage yard with everything needed for the swap. However, will I need to find Turbo manual axles? Will these N/A axles fit into my front hubs? Also, will this flywheel, out of a '96 N/A, work with my '96 turbo? I know I need a "R" clutch, but what about the flywheel? Link to comment Share on other sites More sharing options...
