Boomin850 Posted July 25, 2005 Author Report Share Posted July 25, 2005 I started defluting my lenses last night. Man is it a PITA. I have all the flutes sanded flush now I just need to get rid of the scratches/sanding marks. I picked up some 350-800 grit dry/wet sand paper and some plastic cleaner/polish. Will this remove the "haze" that I currently have?Dave←You're going to need higher grits than that. I have 230, 320, 400, 600, 1000, 1500, and last but not least 2000 grit. Right now I'm redoing the 600 stage because there were a bunch of little dremel marks that I just couldn't polish out like I thought I would be able to. Good luck tho...expect spending a lotta nights in front of the tv sanding.-MIKE DPS...If you have plastic lenses then consider this post retarded Link to comment Share on other sites More sharing options...
exexpat Posted July 25, 2005 Report Share Posted July 25, 2005 PS...If you have plastic lenses then consider this post retarded←I do, and I do Link to comment Share on other sites More sharing options...
