Scan Tech Dot Or Scan Tech E-code
V Tuning 850
Which should I buy? This insludes the turn signals too.
16 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
So as you might or may not know, I am getting some Scan Tech's from FCP Groton. Now I am choice the DOT version or the E-Code version.
I am heading towards the E-Codes. Anyone have any reason to make me change my mind about this?
I will be buying the turn signals as well.
Ok so I just ordered the Scan Tech E-Code headlamp lenses, and turn signal lenses from FCP Groton.
So the question is, how hard of an install is this? I think someone said 30 minutes per side.
What tools would I need as well?
Corners are 30 seconds each.
The headlight lenses depends on how you do it. You can leave the headlight units in the car and remove the covers under the headlight wipers. That allows you access to all the clips. Just a screwdriver to pry off the clips. Very easy.
To put them back on they just snap in place.
i believe ecodes angle the opposite way... meaning they would point to the left of the road instead of the right
i could be mistaken though
So...is this true? This is my deciding factor.
