VNM850 Posted July 3, 2005 Report Share Posted July 3, 2005 i have a question concerning safely installing my boost valve. ive got it, im ready to put it on and test,but im not sure what is a the safe level of adjustment. the directions are quite vauge.- thanks Link to comment Share on other sites More sharing options...
Bay13 Posted July 3, 2005 Report Share Posted July 3, 2005 What boost valve are you talking about? A Manual boost controller? What kind of car and turbo do you have, need to know before giving answers. Do you have a Stock ECU program or an Upgraded ECU? Link to comment Share on other sites More sharing options...
Guest Guest Posted July 3, 2005 Report Share Posted July 3, 2005 What boost valve are you talking about? A Manual boost controller? What kind of car and turbo do you have, need to know before giving answers. Do you have a Stock ECU program or an Upgraded ECU?←woops i suppose that info would be helpfull. ive got a 96 850 turbo(bone stock) -i am installing a manual boost control no ecu upgrades. Link to comment Share on other sites More sharing options...
Bay13 Posted July 3, 2005 Report Share Posted July 3, 2005 Set the manual boost controller up for 9-10PSI.1995: 850, 2.4L normally aspirated engine (168 hp, 162 lb-ft) ----- 850 GLT, 2.4L normally aspirated engine (168 hp, 162 lb-ft), diff in trim and equip. ----- 850 Turbo, 2.3L engine, mitsubishi turbocharger TD04HL-15G (222 hp, 221 lb-ft, 9.6 psi) ----- 850 T5-R, 2.3L engine, mitsubishi turbocharger TD04HL-15G (240 hp, 221 lb-ft, 10.9 psi, limited edition, upgraded suspension and tire/wheel package, different interior, factory external amp a possibility. primary colors are yellow and black, altho a few off colors like green) 1996: same as 1995 except t5-r.----- 850 Platinum Edition, 2.3L engine, mitsubishi turbocharger TD04HL-15G (222 hp, 221 lb-ft, 9.6 psi), many options standard, only color is pearl white----- 850 R, 2.3L engine, mitsubishi turbocharger TD04HL-15G (240 hp, 221 lb-ft, 10.9 psi, not limited anymore, similar to t5-r except no yellow. primary colors red, black, white.) Above taken from the Sticky in the performance section. Link to comment Share on other sites More sharing options...
VNM850 Posted July 4, 2005 Author Report Share Posted July 4, 2005 thank you for the quick reply it will be done tonight. i appreciate all the info Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted July 4, 2005 Report Share Posted July 4, 2005 Do you have a boost gauge?? Link to comment Share on other sites More sharing options...
zazzn Posted July 4, 2005 Report Share Posted July 4, 2005 I'm running 15 psi with nothing just a K&N drop in.. I hooked up my HKS boost gauge termp so I could see waht I was doing then put it back in the supras... Car runs good at this boost.. you actually feel it. Link to comment Share on other sites More sharing options...
