Progress On The S60
Che'_Moderator
  • Replies 81
Top Posters In This Topic
Ohh shiiitt!! Now you're talking!
How about some more engine details?
Compression ratio, internals, valvetrain, cams, ems, turbo? very interested to see what turbo you chose and i can't wait to see the manifold etc..
9:1 compresion, weisco pistons, crank was reworked, valves are over sized, cams are actually OEMs, ETC was replaced with a cable, turbo is GT35R, EMS is a Pectel.
Did you upgrade the cylinder walls or use a stronger cylinder sleeve. I ask as I have seen a S60 guys in Asia
with cracked casting between cylinders where it is thin where they touch like this O|O
I have.... or will have two engines when its done. One was resleaved and ringed, one is not. I don't belive the block itself would have any problems with propper tuning but could be wrong. I am pretty sure the cosworth engines used the same sleaves believe it or not. I will find out
I have been told this cracking problem is strictly harmonic in nature. If the engine is balanced it will not have harmonic problem. It appears these asians had a combination of overheating (you must run a 70-80 termostat) and this heat combined with less than great balancing so I do not think it is an issue for a well built complete engine job type motor
Edited by Helmut Ranff
I can see that as a large amount of biaxial stress is dissipated there. Without knowing for sure though I would guess a lot of that would be due to poor tolerances, as you said, and poor quality material used at the factory, ie poor QC.
Kenneth "Discom" had a solenoid/wastegate mismatch. The same thing I had with my R except with my R I discovered the problem in time..
The result with Kenneth's R was 30+ psi and what appeared to be a nice lean ignition while at it.
With a good turbo and 500 HP I don't think you will see 30 psi.
The ME 7's sensor can only read up to 22.33 psi.
Never looked at this as I pulled the ME7 out, but can the ecu handle more if the MAP was swapped with a 3 bar unit?
  • 2 weeks later...
What kinda RPM are you winding this thing out to? Imagine stock cams might hurt the potential if you're going to 8000+, but I don't know their specs and timing can make a nice difference...
You know what you're doing, just wondering and rambling as usual.
Guest
This topic is now closed to further replies.
