lax01 Posted December 1, 2005 Author Report Share Posted December 1, 2005 lurking and/or not here wasting time Link to comment Share on other sites More sharing options...
rp850 Posted December 12, 2005 Report Share Posted December 12, 2005 I don't understand why the spark plug cover would have to be removed to pull the intake manifold? LOL! PRICELESS! Way to go on finishing it though! Link to comment Share on other sites More sharing options...
yangotang Posted December 12, 2005 Report Share Posted December 12, 2005 I don't understand why the spark plug cover would have to be removed to pull the intake manifold?Because there's a breather hose to the top of the crankcase which runs beneath it :josh: Link to comment Share on other sites More sharing options...
rp850 Posted December 12, 2005 Report Share Posted December 12, 2005 Thanks. Of course!Because there's a breather hose to the top of the crankcase which runs beneath it Link to comment Share on other sites More sharing options...
Qbrozen Posted December 14, 2005 Report Share Posted December 14, 2005 what car is pictured here? 850?does anyone know if this is basically the same in an S70? does this even need to be done in an S70? I've searched and every writeup I can find is for 850s. FCPgroton only lists the kit for 850s, as well.do folks typically wait for oil consumption or leaks to do this maintenance? Or is it suggested that this be done as preventative maintenance?thanks for any info. Link to comment Share on other sites More sharing options...
rp850 Posted December 14, 2005 Report Share Posted December 14, 2005 A good litmus test is to get your car warmed up well and then with the engine running pull the dipstick and oil cap. If you have smoke billowing out, chances are good you may have positive crankcase pressure and the PCV systems should be serviced. If ignored, it could put enough pressure on your engine seals to cause leaks like the dreaded RMS leak. what car is pictured here? 850?does anyone know if this is basically the same in an S70? does this even need to be done in an S70? I've searched and every writeup I can find is for 850s. FCPgroton only lists the kit for 850s, as well.do folks typically wait for oil consumption or leaks to do this maintenance? Or is it suggested that this be done as preventative maintenance?thanks for any info. Link to comment Share on other sites More sharing options...
lax01 Posted December 15, 2005 Author Report Share Posted December 15, 2005 what car is pictured here? 850?does anyone know if this is basically the same in an S70? does this even need to be done in an S70? I've searched and every writeup I can find is for 850s. FCPgroton only lists the kit for 850s, as well.do folks typically wait for oil consumption or leaks to do this maintenance? Or is it suggested that this be done as preventative maintenance?thanks for any info.and yes, it should be the same except for you won't have the EGR on the bottom of your intake manifold (which really doesn't even matter) Link to comment Share on other sites More sharing options...
viperman135 Posted December 15, 2005 Report Share Posted December 15, 2005 Give or take about what mileage should this be done at? I will run the test just wanted to know. As for parts just get this Link. Do you need the whole tune up kit. I know it was said that is was done for $60. Thanks sorry for any nobbie questions I dont hang around maintenance very much. Link to comment Share on other sites More sharing options...
Dmitry S. Posted December 15, 2005 Report Share Posted December 15, 2005 Cool. Link to comment Share on other sites More sharing options...
Qbrozen Posted December 15, 2005 Report Share Posted December 15, 2005 A good litmus test is to get your car warmed up well and then with the engine running pull the dipstick and oil cap. If you have smoke billowing out, chances are good you may have positive crankcase pressure and the PCV systems should be serviced. If ignored, it could put enough pressure on your engine seals to cause leaks like the dreaded RMS leak.nice! thanks for the straightforward answer and easy test. Much appreciated. I'll do it ASAP. Link to comment Share on other sites More sharing options...
Sadude Posted December 15, 2005 Report Share Posted December 15, 2005 Very nice work but did you replace the knock sensors while you were there? I know that there is an "upgrade" to the knock sensors that volvo release that eliminates the multiple connections.great job man, thanks for all the pictures Link to comment Share on other sites More sharing options...
lax01 Posted December 15, 2005 Author Report Share Posted December 15, 2005 Very nice work but did you replace the knock sensors while you were there? I know that there is an "upgrade" to the knock sensors that volvo release that eliminates the multiple connections.great job man, thanks for all the picturesif you're talking to me, then no, I didn't replace/upgrade the knock-sensors....didn't even touch them...I probably will whenever I get around to do the oil pressure/temp gauges... Link to comment Share on other sites More sharing options...
tomtbone Posted March 4, 2006 Report Share Posted March 4, 2006 post rebirth!Did you also replace the actual oil trap? Doe sthis have to be replaced too?T Link to comment Share on other sites More sharing options...
lax01 Posted March 4, 2006 Author Report Share Posted March 4, 2006 no I just sprayed a lot of brake-cleaner in there and it seemed pretty empty....flushed with water and let it dry...I'm pretty sure its just an hollow box...nothing in there but some guides and levels Link to comment Share on other sites More sharing options...
tomtbone Posted March 4, 2006 Report Share Posted March 4, 2006 no I just sprayed a lot of brake-cleaner in there and it seemed pretty empty....flushed with water and let it dry...I'm pretty sure its just an hollow box...nothing in there but some guides and levelscool, I won't waste money on that then. Link to comment Share on other sites More sharing options...
