Zappo Posted September 12, 2005 Report Share Posted September 12, 2005 I've run mine for 1.5 years with no heatshield. Why? Not so I can hear it or any BS reason, but simply cuz I'm always working on it and tweaking things. Plus, how else could you see that cherry red glow when its nice and dark out after a nice spirited drive? I haven't had any temperature problems with it, and its not going to get but so much hotter than a 15g pushing 20psi.-Andy←They aren't talking about the turbo heat shield, they are talking about the sound insulation attached to the underside of the hood. I have had the exhaust glowing on cars with no hood insulation before and haven't had a paint issue. Now if the exhaust was much closer to the hood I could see where there would be a problem. Link to comment Share on other sites More sharing options...
SH8KDWN Posted September 12, 2005 Report Share Posted September 12, 2005 I haven't had a problem yet with the hood insulation being removed. Paint is the same. I would recommend you keep your turbo heat shield on, as you have already heard.You may want to paint the underside of the hood for another reason...Volvo never finished painting under the insulation. If I remember correctly your car is white and the primer is greyish silver. The clips aren't that hard to remove just squeeze below the flat part and they will pull out. They are brittle so expect to break half of them. Link to comment Share on other sites More sharing options...
EMDII Posted September 12, 2005 Report Share Posted September 12, 2005 The clips aren't that hard to remove just squeeze below the flat part and they will pull out. They are brittle so expect to break half of them.←If I Recall Correctly, the clips are 1/4 turn: stick a screwdriver in the slot, turn (lefty loosey), and VOILA! Link to comment Share on other sites More sharing options...
550 Posted September 12, 2005 Report Share Posted September 12, 2005 Not on the s70. ^ Link to comment Share on other sites More sharing options...
SH8KDWN Posted September 13, 2005 Report Share Posted September 13, 2005 I wish it were that easy on an S70. You can slip a screwdrived under the "T" and depress one side of the stem and pull down. Be careful not to brake the side that is parallel with the hood. Link to comment Share on other sites More sharing options...
EMDII Posted September 13, 2005 Report Share Posted September 13, 2005 So much for elegant engineering. :( Link to comment Share on other sites More sharing options...
biged30 Posted September 14, 2005 Report Share Posted September 14, 2005 I would agree that heat shield really does more for sound and along those lines has anyone used that hood liner product from Dynamat? I'm actually looking for less osund coming from my engine (I like my cars to be sleeperes) Link to comment Share on other sites More sharing options...
Zappo Posted September 14, 2005 Report Share Posted September 14, 2005 I would agree that heat shield really does more for sound and along those lines has anyone used that hood liner product from Dynamat? I'm actually looking for less osund coming from my engine (I like my cars to be sleeperes)Dynamat is expensive. Link to comment Share on other sites More sharing options...
