Guest Guest Posted November 18, 2005 Report Share Posted November 18, 2005 Bah, CJ, why no candy apple on the exhaust manifold? Will the powdercoat not be able to take the heat?Alex,I was hoping to Jet Hot coat the later manifold so it would have been a waste of money and I doubt the candy colros will take the exhaust heat. Link to comment Share on other sites More sharing options...
yangotang Posted November 18, 2005 Report Share Posted November 18, 2005 CJ, make sure to take some pics of the blasted-open cylinder wall for good measure! Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted November 18, 2005 Report Share Posted November 18, 2005 CJ, make sure to take some pics of the blasted-open cylinder wall for good measure!OH, I will. I will be pulling the pan off tomorrow to see all the damage done. I got most of it apart after my earlier post. I just couldn't help myself. I did post pics before. Link to comment Share on other sites More sharing options...
the underlørd Posted November 18, 2005 Report Share Posted November 18, 2005 OH, I will. I will be pulling the pan off tomorrow to see all the damage done. I got most of it apart after my earlier post. I just couldn't help myself. I did post pics before.I like the MSPAINT arrow...OMG, that hole isn't supposed to be there? Link to comment Share on other sites More sharing options...
Volvoson Posted November 18, 2005 Report Share Posted November 18, 2005 I like the MSPAINT arrow...OMG, that hole isn't supposed to be there?That's what I was thinking too... Insert a picture of Nat's old motor, it looked identicle :josh: Link to comment Share on other sites More sharing options...
the underlørd Posted November 18, 2005 Report Share Posted November 18, 2005 That's what I was thinking too... Insert a picture of Nat's old motor, it looked identicle hahaha.. good call... that thing was toast.... Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted November 18, 2005 Report Share Posted November 18, 2005 The center cylinder must be the first in the oiling sequence. After it happened, I remember where it got wounded. I was low on oil and was full throttle on a right hand sweeper. What oil was left was on th side of the pan. Sucked the pan dry and ate the first thing in its path, apparently the center rod journal. hence the similarity..."That's what I was thinking too... Insert a picture of Nat's old motor, it looked identicle"VS That's not paint, I don't use MS products unless I absolutely have to. Linux OS here, no viruses, no crashes, no rebooting. Link to comment Share on other sites More sharing options...
Guest DougK Posted November 18, 2005 Report Share Posted November 18, 2005 Pics aren't working atm.Oil Starvation is how John's died too. You described it to a T cj, thats exactly what his was doing when it let loose.Im pretty sure Im going to Accusump mine Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted November 19, 2005 Report Share Posted November 19, 2005 Accusump not needed when oil level correct.OK now we're getting somewhere. Engine out, sub-frame stripped and cleaned. I have decided not to powdercoat the sub-frame because of the rubber mounts pressed into it. I don't want to hassle removing them and replacing them. They are in good enough condition to continue using. I cleaned the sub-frame with mag wheel cleaner and it looks like new. I will likely paint it because some of the area under the battery tray is no longer plated and should be protected from further rust, but all in all it was amazing how clean it came out. Link to comment Share on other sites More sharing options...
narxs70 Posted November 19, 2005 Report Share Posted November 19, 2005 keep the pics comin. subframe looks good. Link to comment Share on other sites More sharing options...
Guest DougK Posted November 19, 2005 Report Share Posted November 19, 2005 Accusump not needed when oil level correct.Aye but its (somewhat) cheap insurance an extra qt of capacity. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted November 20, 2005 Report Share Posted November 20, 2005 Yes, but if not for stupidity I wouldn't be doing this exercise.Got the sub-frame ready. Link to comment Share on other sites More sharing options...
Volvoson Posted November 20, 2005 Report Share Posted November 20, 2005 Looks very well done! Link to comment Share on other sites More sharing options...
BlackT5 Posted November 20, 2005 Report Share Posted November 20, 2005 wow, that looks great! Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted November 20, 2005 Report Share Posted November 20, 2005 Thanks to all for the good remarks.Update 2:00 pm PSTThings are starting to pick up. A lot of cleaning. The transmission is next. I need to fix a broken bolt in the flywheel and get all of my motor mount brackets from the powder coater along with some other brackets tomorrow and I should be able to get the engine in the subframe. I am starting to get impatient. Link to comment Share on other sites More sharing options...
