S70RR Posted February 10, 2006 Report Share Posted February 10, 2006 I have an S70R (outside of US) with 250 HP.I am willing to put a standart throttle body from 850 2.5 without turbo on my car. The throttle body on a non turbo 850 (S70) is bigger than a turbo one.Does anyone know whether it will work, or how many HP gain will I have?I have standart exhaust but without cat. also, only mods I have done is K&N drop in filter and done 2 turns on a waistgate.Thanks :rolleyes: Link to comment Share on other sites More sharing options...
Nebor Posted February 10, 2006 Report Share Posted February 10, 2006 I think a 960 throttle body is even bigger, look into that. Link to comment Share on other sites More sharing options...
S70RR Posted February 10, 2006 Author Report Share Posted February 10, 2006 yes, but will it work on the car? I mean, how many HP gain should I expect roughly?If I do this mod, will the turbo die quicker? Link to comment Share on other sites More sharing options...
the underlørd Posted February 10, 2006 Report Share Posted February 10, 2006 yes, but will it work on the car? I mean, how many HP gain should I expect roughly?If I do this mod, will the turbo die quicker?probably not much.and no. Link to comment Share on other sites More sharing options...
T4R Posted February 10, 2006 Report Share Posted February 10, 2006 yes, but will it work on the car? I mean, how many HP gain should I expect roughly?If I do this mod, will the turbo die quicker?You will probably get better throttle response / acceleration at low rpm (due to increased airflow) but I'm not sure if that will directly translate to any power gains. Ultimately, in a forced induction engine, I'm not sure that the throttle body is the "bottle neck". The downside you'll find going to a larger throttle body is you will get a less "linear" feel to the throttle such that there's probably going to be relatively little difference between going say 70%, 80% or 90% to WOT. Link to comment Share on other sites More sharing options...
Slater Posted February 10, 2006 Report Share Posted February 10, 2006 I think a 960 throttle body is even bigger, look into that.No, I have measured them both. The NA TB and the 960 TB is identical.The main problem you're going to have is finding a coupling to go over the NA/960 TB. The Samco won't. The stock won't. The TB is over 3" OD! This is the main thing keeping me from installing my own NA TB, as I have 4 of them sitting gathering dust! Link to comment Share on other sites More sharing options...
ccsct203 Posted February 11, 2006 Report Share Posted February 11, 2006 Anytime you change a MAF from another car, if it has a larger or a smaller ID, you have to customize the maf signal to your ECU.as long as a MAF is of similar design you can use it.They sell electronics which will modify the signal so nearly any MAF will work. Link to comment Share on other sites More sharing options...
ccsct203 Posted February 11, 2006 Report Share Posted February 11, 2006 sorry I put that last post in the wrong place.I have a 93 850 and I used stock TB and intercooler/TB pipes I had to buy silicone hose parts to make it work. Came out great and looks very clean. Link to comment Share on other sites More sharing options...
550 Posted February 11, 2006 Report Share Posted February 11, 2006 It has been noted that when changing to a larger throttle body, you get less of a turbo "kick". Meaning it comes on more linearly. Will you reallynotice it though? Probably not. Link to comment Share on other sites More sharing options...
S70RR Posted February 11, 2006 Author Report Share Posted February 11, 2006 so as far as I understand there is no point toing for a larger throttle body as there are no HP gains or maybe anyone else has any other ideas about this subject? Link to comment Share on other sites More sharing options...
