Martin Posted February 27, 2006 Report Share Posted February 27, 2006 I called a junkyard today to replace my S70 T5 manual tranny. They had one from a 98, but said my vin number didn't match theirs and it wouldn't work, according to their computer search. Is this true, or should i just ignore this? I just want to know what the difference are between the M56H. Mine's a 98 as well. Thanks for anyone that can clear this up. Link to comment Share on other sites More sharing options...
the underlørd Posted February 27, 2006 Report Share Posted February 27, 2006 is the tranny from a NA?that's why he's saying it won't work i bet. Link to comment Share on other sites More sharing options...
Jason K2 Posted February 27, 2006 Report Share Posted February 27, 2006 Martin's roommate here:It said it was from a turbo. What we're finding when we look for a replacement is that VIN numbers in a certain range "require" a different transmission than VIN numbers in the another range. So far we haven't had an answer as to why they're saying you need a different transmission based on your VIN, turbo or not.is the tranny from a NA?that's why he's saying it won't work i bet. Link to comment Share on other sites More sharing options...
the underlørd Posted February 27, 2006 Report Share Posted February 27, 2006 Martin's roommate here:It's a turboyaya, i know martins car is a turbo, but is the car at the salvage yard a NA? Link to comment Share on other sites More sharing options...
Jason K2 Posted February 27, 2006 Report Share Posted February 27, 2006 yaya, i know martins car is a turbo, but is the car at the salvage yard a NA?Yeah, I realized what I said right after I posted, just edited it. Link to comment Share on other sites More sharing options...
the underlørd Posted February 27, 2006 Report Share Posted February 27, 2006 Yeah, I realized what I said right after I posted, just edited it.gotcha, i mean, i don't see how it could be physically different, but then again, i'm by no means an expert.. so if the junkyard car is a manual, turbo, it's gotta be from a T5M... Link to comment Share on other sites More sharing options...
Jason K2 Posted February 27, 2006 Report Share Posted February 27, 2006 gotcha, i mean, i don't see how it could be physically different, but then again, i'm by no means an expert.. so if the junkyard car is a manual, turbo, it's gotta be from a T5M...The "best" answer I got was "oh, transmissions for those are rare" with no explaination as to why or what the difference is. Kind of a sucky "best" answer, heh, oh well. Here's to hoping an expert chimes in with an answer :) Link to comment Share on other sites More sharing options...
the underlørd Posted February 27, 2006 Report Share Posted February 27, 2006 The "best" answer I got was "oh, transmissions for those are rare" with no explaination as to why or what the difference is. Kind of a sucky "best" answer, heh, oh well. Here's to hoping an expert chimes in with an answer yeah, they are rare for sure..whatever you do, DON'T tell anyone where it is.. i'm not kidding. ps - what's wrong with the one in the car now? just curious. Link to comment Share on other sites More sharing options...
Jason K2 Posted February 27, 2006 Report Share Posted February 27, 2006 yeah, they are rare for sure..whatever you do, DON'T tell anyone where it is.. i'm not kidding. ps - what's wrong with the one in the car now? just curious.From Martin's sig: Mods: quarter sized hole in transmissionSomething exploded out of it, not sure exactly what it was. Link to comment Share on other sites More sharing options...
the underlørd Posted February 28, 2006 Report Share Posted February 28, 2006 From Martin's sig: Mods: quarter sized hole in transmissionSomething exploded out of it, not sure exactly what it was.jeeesus.... that's no good at all. :( Link to comment Share on other sites More sharing options...
boostjunkie Posted February 28, 2006 Report Share Posted February 28, 2006 When did the 4 bolt a-arms start showing up on 70 series?Maybe the axels are different, just a thought.and like kev said, tell no one of the location of that tranny!! Link to comment Share on other sites More sharing options...
azinwa Posted February 28, 2006 Report Share Posted February 28, 2006 The reason why they said it wont work is because it probably has a differant final drive gear ratio.Any M-56-H manufactured from 96 up should work.Look at the decal on your trans, there should be a bar code, trans type "IE" M-56-H, and the final drive gear ratio, 3.73, 4.0Good luckazinwa ;) Link to comment Share on other sites More sharing options...
spottieottie Posted February 28, 2006 Report Share Posted February 28, 2006 you guys... The reason that they are different is becuase in '98 is when they changed the design in the m56h transmissions. There is a chassis break at VIN numbers ending in 395001 for wagons and 459999 for sedans. So this means that any cars ending in (last 6) VIN #'s before or up to this will have the M56H with the external slave cylinder and a throwout fork style throwout bearing and a single mass flywheel.The chassis numbers ending in those numbers and onward use the internal slave cylinder/ hydraulic style throwout bearing and dual mass flywheel. So if your chassis number is from before 459999 than you have the internal style throwout bearing/ fork, and you should find a tranny from another car with a chassis number before the break. PM me if you have any questions. Link to comment Share on other sites More sharing options...
Martin Posted February 28, 2006 Author Report Share Posted February 28, 2006 Ok, Spottieottie, that makes a lot of sense. My last 6 digits in my Vin is 435054. And i have an external slave cylinder. When I ordered my Spec stage II clutch, they sent me one with an internal. Are the clutches the same for both trannies? I would assume so. Thanks for clearing that up. Link to comment Share on other sites More sharing options...
azinwa Posted February 28, 2006 Report Share Posted February 28, 2006 :blink: Every day I walk this Earth I learn something new.Thanks for the great info.NK Link to comment Share on other sites More sharing options...
