andres2882 Posted July 31, 2006 Report Share Posted July 31, 2006 Can someone explain the reverse lights wiring in more detail for me? Link to comment Share on other sites More sharing options...
850turbo Posted July 31, 2006 Author Report Share Posted July 31, 2006 The reverse lights were the blue/blue gray. If you click on the pictures and then when its in the thumbnail click on it again and it will zoom in. I just sliped on the little crimp fittings. Held up for 1/2 a year already. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted August 1, 2006 Report Share Posted August 1, 2006 You are right the cruise control does not work after the swap. I will let you know if cutting the green/red wire does the trick for me. Everything else works great. It is quite an improvement.B.T.W. I have a walnut shift knob and suede boot if you want to go all the way. OEM in the original packaging. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted August 1, 2006 Report Share Posted August 1, 2006 You are right the cruise control does not work after the swap. I will let you know if cutting the green/red wire does the trick for me. Everything else works great. It is quite an improvement.B.T.W. I have a walnut shift knob and suede boot if you want to go all the way. OEM in the original packaging.I cut that green/red wire and the cruise works perfect.Awesome Link to comment Share on other sites More sharing options...
andres2882 Posted August 2, 2006 Report Share Posted August 2, 2006 I'm in the wiring loom but there are two plain blue wires in there. One's fatter than the other, do I need the skinny one or the fat one for the reverse lights? Link to comment Share on other sites More sharing options...
