Seamus Posted June 6, 2006 Report Share Posted June 6, 2006 The light goes on because the air is allowed to pass when it shouldn’t or no air when it should. A one way valve may keep a new valve from failing because it keeps EXH from reaching it and it may keep the air pump from failing if the SAS valve was stuck open (hence failed) But it sounds like a new SAS valve is going to be the only thing that is going to turn off the light. A one way valve would have to be a valve that can stand high ambient as well as working temp so if you do use one…. Don’t put your tongue on it. Link to comment Share on other sites More sharing options...
the underlørd Posted June 6, 2006 Report Share Posted June 6, 2006 The light goes on because the air is allowed to pass when it shouldn't or no air when it should. A one way valve may keep a new valve from failing because it keeps EXH from reaching it and it may keep the air pump from failing it the valve SAS valve was stuck open (hence failed) But it sounds like a new SAS valve is going to be the only thing that is going to turn off the light. A one way valve would have to be a valve that can stand high ambient as well as working heat so if you do use one…. Don't put your tongue on it.good point.gracias. Link to comment Share on other sites More sharing options...
aldug Posted June 7, 2006 Report Share Posted June 7, 2006 I have a '98 V70XC turbo and I also got the dreaded P0410 check engine light error. I determined both the valve and the pump were bad and replaced them both. In replacing valve, the end of the hose which connects the air pump and the valve was so hard and brittle on the valve end that it cracked. Cutting the split end off made the hose too short to fit. What do I use to replace this hose? Is this a special volvo part, or do I just look for some black hose that is the right size? Link to comment Share on other sites More sharing options...
Figawi Posted June 7, 2006 Report Share Posted June 7, 2006 I have a '98 V70XC turbo and I also got the dreaded P0410 check engine light error. I determined both the valve and the pump were bad and replaced them both. In replacing valve, the end of the hose which connects the air pump and the valve was so hard and brittle on the valve end that it cracked. Cutting the split end off made the hose too short to fit. What do I use to replace this hose? Is this a special volvo part, or do I just look for some black hose that is the right size?i have an extra one in if you need a hose. i think. Link to comment Share on other sites More sharing options...
Figawi Posted June 7, 2006 Report Share Posted June 7, 2006 ok i have replaced the air pump and sas valve and all the hoses and vac line. i've driven it for 350 miles and the CEL hasn't come back on. am i safe to go to the inspection station again so they can pass it or should i keep driving it longer? Link to comment Share on other sites More sharing options...
Seamus Posted June 8, 2006 Report Share Posted June 8, 2006 350 miles? That should be long enough.. Link to comment Share on other sites More sharing options...
Figawi Posted June 8, 2006 Report Share Posted June 8, 2006 it passed this morning. yay! Link to comment Share on other sites More sharing options...
pfeener Posted June 8, 2006 Report Share Posted June 8, 2006 Emerysmith; glad you're system passed. It was a long road. You should pick up an Inova 3030 or something like it so you can read your codes and you'll know when all the monitors have finished running. I bought a new one off ebay for $52 including shipping. Link to comment Share on other sites More sharing options...
Figawi Posted June 8, 2006 Report Share Posted June 8, 2006 i have an obdii scanner. is the Inova 3030 something different? Link to comment Share on other sites More sharing options...
pfeener Posted June 8, 2006 Report Share Posted June 8, 2006 Nope it's juat a regular old scanner. It sounded like you didn't know if your system was going to pass inspection or not. The 3030 will tell you if all the monitor routines have run and passed, maybe yours does as well, sorry if I misunderstood. Link to comment Share on other sites More sharing options...
Figawi Posted June 8, 2006 Report Share Posted June 8, 2006 mine does. i left it at my beach house last weekend so I was without it yesterday. Link to comment Share on other sites More sharing options...
Patrickw Posted June 20, 2006 Report Share Posted June 20, 2006 The SAS valve? is that the thing that looks like a little fuel filter and has a wire plugged into it and costs around $125. Thanks, Patrick Link to comment Share on other sites More sharing options...
the underlørd Posted June 20, 2006 Report Share Posted June 20, 2006 The SAS valve? is that the thing that looks like a little fuel filter and has a wire plugged into it and costs around $125. Thanks, Patrickmost likely. Link to comment Share on other sites More sharing options...
Figawi Posted June 20, 2006 Report Share Posted June 20, 2006 yup. it cost around $80 at FCP Groton. Link to comment Share on other sites More sharing options...
pfeener Posted June 20, 2006 Report Share Posted June 20, 2006 It does look like a fuel filter. It's on the back side of the engine; sticking up in the middle, but there's no wires running to it. There's a purple vacuum line and a hose from the air pump. Link to comment Share on other sites More sharing options...
