Serge Posted June 23, 2004 Author Report Share Posted June 23, 2004 are the lights next to the Shifter supposed to light upfrom the factory? Mine don't light up and i can't remeber if they ever did.Yep, there is a bulb there. Getting there requires pulling up the entire center console; but that's a simple task. Link to comment Share on other sites More sharing options...
JehovArob Posted November 12, 2004 Report Share Posted November 12, 2004 Looking into doing this once again. 2 questions:What intensity (mcd?) should I look for in an LED?And did you ever have any luck getting them to work for your dash? Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted November 12, 2004 Report Share Posted November 12, 2004 Im gonna do my dash in blue over christmas break. I think ill used deffused lenses. Link to comment Share on other sites More sharing options...
boostjunkie Posted November 12, 2004 Report Share Posted November 12, 2004 That is pretty sweet man, nice work How long did they entire process take you? Link to comment Share on other sites More sharing options...
Serge Posted November 12, 2004 Author Report Share Posted November 12, 2004 That is pretty sweet man, nice work How long did they entire process take you?←Oh wow this thread is old!Anywho.. I'm not sure, it was tedious sanding the LEDs and carefully soldering the SMT resistors. A good hour, that's for sure. Link to comment Share on other sites More sharing options...
JehovArob Posted November 12, 2004 Report Share Posted November 12, 2004 Actually, if you look up a bit, I was asking what intensity of LEDs would work best for this and if you ever got it to work with your dash lights. Link to comment Share on other sites More sharing options...
Figawi Posted November 12, 2004 Report Share Posted November 12, 2004 where did u order the LEDs from liquid? Link to comment Share on other sites More sharing options...
Serge Posted November 13, 2004 Author Report Share Posted November 13, 2004 where did u order the LEDs from liquid?←eBay was the only place I could find 3mm orange LEDs cheap. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted November 13, 2004 Report Share Posted November 13, 2004 Im getting mine from http://www.moreleds.com, they have these inverted cone LEDs that I think might work on the prisms in the gauges, and they have orange LEDs for $.30, and the guy is really knowledgeable. Link to comment Share on other sites More sharing options...
JehovArob Posted November 13, 2004 Report Share Posted November 13, 2004 C'mon. Can you answer my questions already, please? Link to comment Share on other sites More sharing options...
Serge Posted November 13, 2004 Author Report Share Posted November 13, 2004 Looking into doing this once again. 2 questions:What intensity (mcd?) should I look for in an LED?And did you ever have any luck getting them to work for your dash?←There is a said rule about LED intensity rating. First of all, a clear lens LED will ALWAYS have a higher mcd rating than a diffused LED. Why? because mcd is measured at one point, normally at the very tip of the LED a few inches (?) away. Let me illustrate...An clear lens LED with 30 degrees of light output may register 1000mcd. Whereas as the same type of LED with 15 degrees of light output may register 2000mcd. See where I'm getting at?Diffused LEDs are just the same LEDs except with very large angles, sort of say. Basically, look for the highest MCD rating you can find at the widest angle possible (depending on your application, of course).Okay, as for the dash. I was planning to just take the thing apart and angle the widest angle orange 3mm LEDs directly into the prisms that are under there. It would take a bunch of LEDs and might look ghetto on the inside, but who knows, I might just work :) Link to comment Share on other sites More sharing options...
JehovArob Posted November 13, 2004 Report Share Posted November 13, 2004 Ok, cool. Thanks.So, how many prisims are in there? There are 4 bulbs. Are there like 2 (or more?) for each?Any reason not to do the turn signal lights with LEDs as well? You'd only need 1 for each, right? Link to comment Share on other sites More sharing options...
AnthonyR Posted November 13, 2004 Report Share Posted November 13, 2004 Could a mod or supermod fix the typo in my title? "proceed" ←Done! :) Link to comment Share on other sites More sharing options...
Serge Posted November 14, 2004 Author Report Share Posted November 14, 2004 Ok, cool. Thanks.So, how many prisims are in there? There are 4 bulbs. Are there like 2 (or more?) for each?Any reason not to do the turn signal lights with LEDs as well? You'd only need 1 for each, right?←There are quiet a few, I think. The turn signals I'd leave as they are, it'd be hard to change the color given the green filter. If you shine red/orange light through, nothing will come out since the green filter will absorb it. Link to comment Share on other sites More sharing options...
prasamin Posted November 14, 2004 Report Share Posted November 14, 2004 are the lights next to the Shifter supposed to light upfrom the factory? Mine don't light up and i can't remeber if they ever did.←yeah, supposed to light up....mine has already gone out twice...too lazy/busy to get in there and replace it for now....but yeah, to answer your question! Link to comment Share on other sites More sharing options...
