impulse922 Posted July 19, 2006 Report Share Posted July 19, 2006 Hello to all and sorry to interrupt but, can you tell me more about this systems?I've heard this Rex/Regina and Regina systems, but don't know much about them. Is the only diference the MAP sensor? What is you call LH 2.4?Thanks for any info you can share.pretty much everything is different about them. Lh 2.4 has a head mounted dizzy, 2 fuel pumps, larger injectors(so i've been told), and a cylindrical coil.Rexx/regina has a block mounted dizzy, i believe one fuel pump(in tank), smaller injectors, and a coil more similar to an 850. Link to comment Share on other sites More sharing options...
Lucky Avalon Posted July 19, 2006 Report Share Posted July 19, 2006 Basically the fuel and air intake is the one that changes. Interesting... but, the displacement is the same? Same bore/stroke ratio? Same cylinder heads and cams? Any exhaust difference? Trying to find out if buying or interchanging parts could bring more power to mine.Thanks for the response!! Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 19, 2006 Report Share Posted July 19, 2006 LH 2.4 is the Bosch engine management system. that is why they are saying it, it is the most used as far as I know. Link to comment Share on other sites More sharing options...
Tupapison Posted July 19, 2006 Author Report Share Posted July 19, 2006 Besides that, is there any difference? like lucky asked? Does the LH 2.4 makes the car faster or not? Link to comment Share on other sites More sharing options...
Lucky Avalon Posted July 19, 2006 Report Share Posted July 19, 2006 Ok! understood.. I have this neat little table with the different engine management systems for Volvo:Volvo 940 2 litre - 92 on - Bosch LH 2.4 Volvo 940 2 litre (B200E) - 90-91 - Bosch EZ118K Ignition Volvo 940 2 litre 16 Valve Cat - 90-91 - Bosch LH 2.4 Volvo 940 2.0 litre - 1992 - MAF Volvo 940 2.0 Litre - 95 on - LH2.4 Volvo 940 2.3 - 91-92 - LH2.4 Volvo 940 2.3 - 89 - 96 - Jet/LH2.2 I understand that all 2 litre engines are B200 configurations that were marketed in Europe, and the mayority are the Regina engine management system.Now there are two engine systems for 940 developed for the B230, one is the Regina. But... then the Jet is the Rex/Regina system? or is it the LH2.2? Or is it the combo, Jet/LH2.2?Sorry to keep asking, but I though and was under the impression that all B230's were alike, seeing that every Volvo in the 200, 700, and 900 series here has the same engine management system. As well as others I've seen in internet through various pages as Cardomain and eBay.This is so interesting, I've got manuals of engine performance and I've never stubled across this. So, maybe if having a swap of engine management systems one can get bigger output in an engine that was designed for another? What about the computers, can they be tricked?I'll keep looking for more info, but any other info you can get posted here would be appreciated.Later!! :) Link to comment Share on other sites More sharing options...
Lucky Avalon Posted July 19, 2006 Report Share Posted July 19, 2006 UPDATE!!! Found this chart in Vlvworld!For the B230F engine there are three management systems:85-88 - LH2.289-93 - LH2.491-95 - LH3.1What are the diferences? According to the chart all give the same HP and Torque at the same speed. That is why I thought all B230 are alike, but I could be wrong.The B230A, B230E, B230ET, B230FT have other management systems, but those are good for another post.Later!! Link to comment Share on other sites More sharing options...
TheMan5952 Posted July 20, 2006 Report Share Posted July 20, 2006 Jet is LH system. It is technically called Bosch LH Jetronic x.x then there was also Monitronic on the olderones. and 99+ volvos use what's called ME7.The different numbers are just liek a version diffreence generally for different Emissions requirements. Link to comment Share on other sites More sharing options...
impulse922 Posted July 20, 2006 Report Share Posted July 20, 2006 UPDATE!!! Found this chart in Vlvworld!For the B230F engine there are three management systems:85-88 - LH2.289-93 - LH2.491-95 - LH3.1Lh 3.1 was only found on 90+ 240 Manual cars Link to comment Share on other sites More sharing options...
impulse922 Posted July 20, 2006 Report Share Posted July 20, 2006 Now there are two engine systems for 940 developed for the B230, one is the Regina. But... then the Jet is the Rex/Regina system? or is it the LH2.2? Or is it the combo, Jet/LH2.2?Sorry to keep asking, but I though and was under the impression that all B230's were alike, seeing that every Volvo in the 200, 700, and 900 series here has the same engine management system. As well as others I've seen in internet through various pages as Cardomain and eBay.This is so interesting, I've got manuals of engine performance and I've never stubled across this. So, maybe if having a swap of engine management systems one can get bigger output in an engine that was designed for another? What about the computers, can they be tricked?I'll keep looking for more info, but any other info you can get posted here would be appreciated.Later!! There are only two engine systems on 940's n/a and turbo, ALL turbo cars are LH 2.4 which is bosch jetronic.On n/a 940's you either had a n/a version of lh 2.4 or rexx/regina.rexx/regina and bosch LH 2.4 are the engine management systems.Its kinda like having a computer unless its a mac, its compatible with windows OR linux.All b230's are alike engine wise within their year models.Some have said the the lh 2.4 cars are more ballsier than the rexx/regina cars.Hope some of this helps you guys understand better.-Matt Link to comment Share on other sites More sharing options...
Tupapison Posted July 20, 2006 Author Report Share Posted July 20, 2006 There are only two engine systems on 940's n/a and turbo, ALL turbo cars are LH 2.4 which is bosch jetronic.On n/a 940's you either had a n/a version of lh 2.4 or rexx/regina.rexx/regina and bosch LH 2.4 are the engine management systems.Its kinda like having a computer unless its a mac, its compatible with windows OR linux.All b230's are alike engine wise within their year models.Some have said the the lh 2.4 cars are more ballsier than the rexx/regina cars.Hope some of this helps you guys understand better.-MattWhat do you mean by "ballsier"? Link to comment Share on other sites More sharing options...
impulse922 Posted July 21, 2006 Report Share Posted July 21, 2006 What do you mean by "ballsier"?ahah, a bit more power Link to comment Share on other sites More sharing options...
Guest robdiesel.com Posted July 26, 2006 Report Share Posted July 26, 2006 What the pictures are showing is the hose connecting the airbox via a valve to the California emissions crap. The Pulsair system. Mine cracked to0o and the dealer wanted $45 for it. FCPGroton and IPD wanted around $30-$36 so I skipped it, dabbed some silicone on it and let it be. Link to comment Share on other sites More sharing options...
Guest sinwagon Posted July 28, 2006 Report Share Posted July 28, 2006 heh, my uncle offered his car for 15k, a 2003 lexus es300....... =]]]]Pretty sweet deal, this car is worth 23k actually =]23K for a used Toyota Camry with Lexus badges- sweet! :lol: Link to comment Share on other sites More sharing options...
rodrigo Posted July 29, 2006 Report Share Posted July 29, 2006 OR you can get that S70 T5M and save the 10k towards buying a house with a garage to mod the S70 in. S:tup: Link to comment Share on other sites More sharing options...
