Bay850 Posted June 26, 2006 Report Share Posted June 26, 2006 Im talking about the stock foglights on the 850s, '97 to be exact. Im trying to get the foglights to engage w/o having the headlights on. I know this has already been discussed and ive read the how-to on it. But what im having trouble with is sliding the "metal part" out as described in step 6....."6) Now heres the hard part, you need to slide the metal part out, it has tabs, now one side dosnt really matter if you keep the plastic mounting spot intact, but the otherone will help hold it in the new position, you need to pull it out and reinsert it like this..." BEFORE:AFTER:The problem is getting the piece out because the tabs wont let it happen. I tried using a swiss army knife to hold down the tab and pull the other side of the metal piece with plyers lol. Also im worried about somehow breaking the metal piece or the relay as a whole. Does anyone know the consequences of that? Arright THANKS!! Link to comment Share on other sites More sharing options...
97Rwagon Posted June 26, 2006 Report Share Posted June 26, 2006 I see to much skin. LoL, jk.Repost? I could of sworn I have seen those little green things before. Link to comment Share on other sites More sharing options...
ViperVette Posted June 26, 2006 Report Share Posted June 26, 2006 he was asking a question as to how to get it to work. Link to comment Share on other sites More sharing options...
DARKSIDE Posted June 26, 2006 Report Share Posted June 26, 2006 Im talking about the stock foglights on the 850s, '97 to be exact. Im trying to get the foglights to engage w/o having the headlights on. I know this has already been discussed and ive read the how-to on it. But what im having trouble with is sliding the "metal part" out as described in step 6.....I know exactly what you mean...I did this mod 2 weeks ago and this was the hardest part for me too...These are the tools you'll need:1) small but very stong phillips screw driver2) wrench (the one that locks and can clamp on to something...has one lever to tighten grip and one to loosen grip)---sorry about not knowing the exact name---Use the small phillips to bend the tiny clip in the opposite direction of where it was made to hook onto the plastic...Now you might not notice that it's (the clip) bending, but after a while (10mins.)...Your also going to have to use the same phillips and a hammer(small, or something else to hit the phillips with) to open up the space on the outer side. Try it until u can see a lil' bit of the clamp...Hold the phillips in position (on the inner side) and try to bend the clip even more, while now pulling on the outer part of the metal peice with the clamping wrench. Remember you won't break the metal by pulling on it, just try not to bend the connector too much...Work on one side at a time...Once you get one side slightly out work on getting the other side out...I spent about an hour on the whole process... Link to comment Share on other sites More sharing options...
97Rwagon Posted June 26, 2006 Report Share Posted June 26, 2006 he was asking a question as to how to get it to work.ooohhh. I should really start reading all of the text before i post. :unsure: Link to comment Share on other sites More sharing options...
maiku Posted June 26, 2006 Report Share Posted June 26, 2006 1. it's a bitch to get out2. don't be afraid to mutilate that piece Link to comment Share on other sites More sharing options...
NGB Posted June 27, 2006 Report Share Posted June 27, 2006 2) wrench (the one that locks and can clamp on to something...has one lever to tighten grip and one to loosen grip)Vise Grips :) Link to comment Share on other sites More sharing options...
Volvoson Posted June 27, 2006 Report Share Posted June 27, 2006 I found that the angrier I got at the relay, the less progress I made in getting the tab out... I took a 20 minute "break", picked up my pliers and started yanking and it came right out. Just keep trying to pull, it will come out eventually. Link to comment Share on other sites More sharing options...
yangotang Posted June 27, 2006 Report Share Posted June 27, 2006 mine was pretty easy to get out with needlenose pliers being held in a vise Link to comment Share on other sites More sharing options...
Ivanfbi Posted June 27, 2006 Report Share Posted June 27, 2006 I just heated it up with heat gun and used screw driver, came out very easily Link to comment Share on other sites More sharing options...
DARKSIDE Posted June 27, 2006 Report Share Posted June 27, 2006 I just heated it up with heat gun and used screw driver, came out very easilySmart Move, wish I had thought of that when I was doing mine...would've cut down on some time... Link to comment Share on other sites More sharing options...
brick-a-brac Posted June 28, 2006 Report Share Posted June 28, 2006 Would any of our European bretheren be able to tell us whether this relay has the same PN across the pond? Link to comment Share on other sites More sharing options...
Mesoam Posted June 28, 2006 Report Share Posted June 28, 2006 dremel with the tiny "engraving" bit worked wonders...i took one stab at it with pliers and headed for the bench... Link to comment Share on other sites More sharing options...
Volvoson Posted June 28, 2006 Report Share Posted June 28, 2006 Would any of our European bretheren be able to tell us whether this relay has the same PN across the pond?It is a different relay, but not worth the money to buy it... Link to comment Share on other sites More sharing options...
