UsmcScott Posted July 25, 2006 Author Report Share Posted July 25, 2006 Thanks S70 OK, when I accelerate hard, as the car shifts into overdrive? I do seem to hear a ka-lunk. Do I have to replace some seal, and if so, should I do that before changing the gear oil ? Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted July 31, 2006 Report Share Posted July 31, 2006 Sorry for the delay in responding, been out of town. Odds are the clunk is related to either the drive shaft center support bearing, a bad u-joint or a damaged/failed suspension bushing, the fire could have damaged any of those. The rubber support for the center bearing might just be worn out, or the metal spring might be sagging and need replacing, both are pretty cheap.Also if the exhaust system was tweaked or is otherwise out of position, it too could possibly make body contact under those conditions. Link to comment Share on other sites More sharing options...
