"r" Calipers
  • Replies 30
Top Posters In This Topic
what all does it take to install the R calipers on my 94 850 turbo?? all im asking for is help not a re-direction.
Forget about the front ones....not gonna happen. For the rears you will need the brackets made by CJ (330+T5R) and a 5mm spacer iirc (and 17's that will clear them)
rear brackets are $125 + sh from CJ btw
so the only way to go with 4 pots would be to go with a big brake kit with 4 pots?
Not exactly sure what you are saying but here is what you can do that are more common...
Front-
Porsche
Wilwood
Stoptech
WP Pro
Rear-
S60R
Stoptech
Wp Pro
Forget about the front ones....not gonna happen. For the rears you will need the brackets made by CJ (330+T5R) and a 5mm spacer If I recall Correctly (and 17's that will clear them)
rear brackets are $125 + sh from CJ by the way
Thought I saw a post a few weeks ago regarding a bracket to mount the FRONT R calipers to 850 & 70 series volvos. Perhaps a SEARCH would yield some results?
-Jon
-Jon
There was a post...but the amount of steel holding the calliper on was minimal....I will stick with my other brakes before those...and I even have all 4 corners of the R calipers sitting here
Front-
Porsche
Wilwood
Stoptech
WP Pro
Rear-
S60R
Stoptech
Wp Pro
Forgot to mention AP Racing in the front setup...
I read over at some Euro-based forum that Volvo has a 320mm (yes, that's 320mm not 302mm) brake upgrade kit. The fellow installed it in his 850, he even listed the part numbers. I saw the pics but it wasn't the R calipers. Probably more like the brakes for the s80 or xc90. Anyone know or have details on this kit?
