TEKVOLVO Posted July 21, 2006 Report Posted July 21, 2006 The long awaited pipe is nearly complete, i'm sure mike will post pics when it's back from the welder. just a bit of props: mike's car is allready very fast... it should be even faster now that mike has finally hit a full 3 inches. :D
JHEIII874T5M Posted July 21, 2006 Report Posted July 21, 2006 Sounds good, make sure you turn the boost down a bit.
prasamin Posted July 21, 2006 Report Posted July 21, 2006 Sounds good, make sure you turn the boost down a bit.blasphemy!! why would you do something so disgusting?
POOKDIZZLE Posted July 21, 2006 Report Posted July 21, 2006 Pics to come of my new 3" still got a couple of little things to do before it goes on the car, hopefully it'll be on tonight B)
thelostartof Posted July 21, 2006 Report Posted July 21, 2006 blasphemy!! why would you do something so disgusting?because on most all turbo cars when going from smaller to larger ID downpipes you will pick up 1-2 psi if not more
TEKVOLVO Posted July 21, 2006 Author Report Posted July 21, 2006 because on most all turbo cars when going from smaller to larger ID downpipes you will pick up 1-2 psi if not moremike will be happy to hear that! the more the better, then the NOS., then the bang, clatter clatter, scrape, fizzle....darn. :blink:
Zulu Posted July 21, 2006 Report Posted July 21, 2006 because on most all turbo cars when going from smaller to larger ID downpipes you will pick up 1-2 psi if not moreTrue story.
POOKDIZZLE Posted July 22, 2006 Report Posted July 22, 2006 Downpipe is ON picked up about 2psi running @ 19-20psi now and the throttle response seems a lot better, thanks to TEKVOLVO for all the help I'll take some pics Monday(I have a lift at work) and post em' up Thanks to everyone on here for all the help especially JESSE850 and TEKVOLVO :)
JESSEXC Posted July 22, 2006 Report Posted July 22, 2006 Downpipe is ON picked up about 2psi running @ 19-20psi now and the throttle response seems a lot better, thanks to TEKVOLVO for all the help I'll take some pics Monday(I have a lift at work) and post em' up Thanks to everyone on here for all the help especially JESSE850 and TEKVOLVO HAHAHA about damn time. Here is one of my favorite PMs I can't get the pipe onto the turbo when it's all tacked together, I can't snake it up to fit on the studs and I don't even have the cat on there yet! Do I drop the subframe to do this or is there another way to throw it on?? This is quite the job man
Texas850Turbo Posted July 22, 2006 Report Posted July 22, 2006 19-20 psi without a built bottom end???? Either you're going to bend a rod here in the next few seconds or that's a tad exaggerated....
Overboost850 Posted July 22, 2006 Report Posted July 22, 2006 19-20 psi without a built bottom end???? Either you're going to bend a rod here in the next few seconds or that's a tad exaggerated....Or ya know, you just don't know what you are talking about... ;)
POOKDIZZLE Posted July 22, 2006 Report Posted July 22, 2006 19-20 psi without a built bottom end???? Either you're going to bend a rod here in the next few seconds or that's a tad exaggerated....Wow, you are right how does the Underlord, Javodoc, '95R and Torquesteer to name a few, seem to run @ 19psi w/o bending rods for all this time, maybe they should play the lottery :rolleyes:
