Manual B Oost Controller,, Only 10# Of Boost
wlfbronco
Did you install the vacuum lines correctly on the MBC? Inlet is the line from the turbo, outlet goes to the wastegate.
It's likely installed backwards, I had the same problem when I put mine in! :rolleyes:
i get that much plus change in every gear, ebc
Me too, funny how EBC's work like that, isn't it? :P
I have the Hallman, it came with two springs. I used the HEAVY SPRING with no issues at all.
Well, besides my pathetic 15g not holding boost to redline. But it goes to where I set it and then fades out. So the controller is doing its job.
PUt the heavier spring in today,,, that was the issue,,, soft spring just wastn holding,,, I put the new spring in and it easily hit 13# very quick,, much faster than using the stock EBS at the adjustment I had obn it,, so about another turn and I"ll be alll good,,,
Thanks to all who replied,,,,,
How high do you have yours set, 25psi? That way it fades to ~18psi and all is well with a nice amount of torque down low?? :P
haha, not exactly. I was running about 18psi which gives a huge torque spike down low. But it would fade off horribly. I've lowered it down some, maybe 15 or so now. Its more even but its just time to ditch the 15g. Wish I had the time to mess around with the T3 sitting in my garage all plumbed and ready to go....
Using a T-bird Pull? And your rims are poking sick wlfbronco. Sorry off-topic, but compliments are always on-topic.
Did you try all the gears? I can only get 11 psi in 1st, but I boost 14 psi nicely in the others. I don't really see why you have a MBC if you're chipped and boosting fine with the chip.
+1
+2
