freeskier8585 Posted July 26, 2006 Report Posted July 26, 2006 So my rica chip took a vacation but nothing was changed on it (long story) finally got it back in the car with an ebc and bov. So its got some nasty torque down low, but when i push up to 18psi, the afr's are in the 11-12:1 range, and it seems to be pulling timing or something, if i turn down the boost to a modest 16 i dont get the problems. This is a 19t, 18psi rica remap for the 19t and blue injectors.
Swedish Mike Posted July 26, 2006 Report Posted July 26, 2006 So my rica chip took a vacation but nothing was changed on it (long story) finally got it back in the car with an ebc and bov. So its got some nasty torque down low, but when i push up to 18psi, the afr's are in the 11-12:1 range, and it seems to be pulling timing or something, if i turn down the boost to a modest 16 i dont get the problems. This is a 19t, 18psi rica remap for the 19t and blue injectors.Sounds like the good old plug problem./Mike
freeskier8585 Posted July 26, 2006 Author Report Posted July 26, 2006 Good old blow out? Thats what i was thinking, ill switch them out today and let you guys know whats up... recomended gapfor high boost, was it .023?
gdizzle Posted July 26, 2006 Report Posted July 26, 2006 Good old blow out? Thats what i was thinking, ill switch them out today and let you guys know whats up... recomended gapfor high boost, was it .023?.023 should work fine.
the underlørd Posted July 26, 2006 Report Posted July 26, 2006 and it seems to be pulling timing or something altitude + ambient temps ?
TorqueSteer Posted July 26, 2006 Report Posted July 26, 2006 Good old blow out? Thats what i was thinking, ill switch them out today and let you guys know whats up... recomended gapfor high boost, was it .023?.23 works, but .25 should work as well, if you are getting blowout or misfiring at .25 gap, id look into your ignition system to see if there is anything worn out that needs changing, theres 850's making tons more power than you are, with stock ignition and .25 gap.
gdizzle Posted July 26, 2006 Report Posted July 26, 2006 .23 works, but .25 should work as well, if you are getting blowout or misfiring at .25 gap, id look into your ignition system to see if there is anything worn out that needs changing., theres 850's tons more power than you are, with stock ignition and .25 gap.I don't know anyone runing .25
TorqueSteer Posted July 26, 2006 Report Posted July 26, 2006 I don't know anyone runing .25Well i do :)
gdizzle Posted July 26, 2006 Report Posted July 26, 2006 Well i do you obviously didn't get the joke. it's .025 not .25. .25" is one hell of a gap for a spark plug.
freeskier8585 Posted July 26, 2006 Author Report Posted July 26, 2006 kev- it was at night...almost cold and everything that makes the sparky go spark has less than 10,000 miles on it
turbobrick Posted July 26, 2006 Report Posted July 26, 2006 you obviously didn't get the joke. it's .025 not .25. .25" is one hell of a gap for a spark plug.wise jerk. :monkey:
