Why Is My Boost Stupid
So my rica chip took a vacation but nothing was changed on it (long story) finally got it back in the car with an ebc and bov. So its got some nasty torque down low, but when i push up to 18psi, the afr's are in the 11-12:1 range, and it seems to be pulling timing or something, if i turn down the boost to a modest 16 i dont get the problems. This is a 19t, 18psi rica remap for the 19t and blue injectors.
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
Sounds like the good old plug problem.
/Mike
Good old blow out? Thats what i was thinking, ill switch them out today and let you guys know whats up... recomended gapfor high boost, was it .023?
.23 works, but .25 should work as well, if you are getting blowout or misfiring at .25 gap, id look into your ignition system to see if there is anything worn out that needs changing, theres 850's making tons more power than you are, with stock ignition and .25 gap.
.23 works, but .25 should work as well, if you are getting blowout or misfiring at .25 gap, id look into your ignition system to see if there is anything worn out that needs changing., theres 850's tons more power than you are, with stock ignition and .25 gap.
I don't know anyone runing .25
