Leaking Tranny Fluid And Cooling Fan Issue
lcc014
2 days ago, I found a couple of oil drops on the driveway. I checked under the car and found out that "red/pink" tranny fluid was under the tranny case. Upon looking further, it looked like tranny fluid was leaked out from the area where the passenger side half axle into the tranny. Can the seal ring of the half axle be replaced to fix the fluid leak ?
Another issue is with the cooling fan. It makes noise when running. Can it be lub. to reduce the noise or I have to get a new cooling fan ?
My car is now over 160k miles and will be 11 years old in October.
Any suggestion is appreciated.
Ching-Ho Cheng
Ching-Ho Cheng
yes, axle seals can be replaced.
cooling fan I don't know.
as was said,
yes, axle seals can be replaced easily.
Fan noise...
is there somethin' rubbin', or are the bearings gone? Darn, them fans are expensive!
Not the rubbin noise, sounds like bearings gone !! I looked at FCP Groton and the aftermarket fan is around $190. Not sure how much more from dealer.
I will ask Volvo garage in Boston to replace the seals. Should I replace both sides or just the leaking side ?
Thanks,
Ching-Ho Cheng
replace both sides its smarter in the long run. preventive maintenance you could say B)
Thing is, each axle is removed separately. There is no "time savings" by doing both, well except for the fact that the car is in the shop just once.
If the CV booties are old & worn, handling the axles may cause them to fail right away or shortly thereafter. Old boots are fragile. I've learned that lesson the hard way!
Ching-Ho, is this something you could do yourself? The parts are cheap, and it's a pretty straigh-forward job.
Russ,
I have not done the axle nut and the removal of half axle before so I am not confident to do so. I did the ball joint/control arm and strut/shock, engine mount, radiator replacement before. I don't know whether I can do it or not especially after reading many posts regarding to the difficulty of half axle removal from tranny.
I will replace the cooling fan myself because I replaced radiator and starter before. So I have experience on this task.
Thanks,
Ching-Ho Cheng
Just got the cooling fan (Volvo brand) this afternoon and installed. The part was about $365. Dealer part department told me that there are 2 types of cooling fan - one type has 2 speeds and other has 1 speed. According to my car's VIN, the single speed fan is for my car.
I will try to replace the coolant expansion tank on Thursday because tomorrow is very very hot (100 degree).
Thanks,
Ching-Ho Cheng
Guest AlvinL
Thanks,
Ching-Ho Cheng
That's good to know and thanks for sharing that. I thought they were all two speeds due to a/c. I see FCP sells the one kind...
If the last 6 digits of your car's VIN is smaller/less than 056851, then the cooling fan is dual speeds (p/n 9141249).
If the last 6 digits of your car's VIN is higher than 056852, then the cooling fan is single speed (p/n 9141248).
Since the last 6 digits of my car's VIN is greater/higher than 056852, so my car uses the single speed cooling fan.
The price difference is about $100 and dual speed fan is cheaper than single speed fan .....
Ching-Ho Cheng
