maximase86 Posted October 13, 2006 Report Share Posted October 13, 2006 Question, currently I run rebased D2R bulbs. They run off Denso OEM ballasts. Can I get bulbs compatiable with this type of ballast that will fit 9006? I really would like to get 6000k bulbs if I can.S Link to comment Share on other sites More sharing options...
leurven Posted October 13, 2006 Author Report Share Posted October 13, 2006 Question, currently I run rebased D2R bulbs. They run off Denso OEM ballasts. Can I get bulbs compatiable with this type of ballast that will fit 9006? I really would like to get 6000k bulbs if I can.SI think so. Are they AMP style connectors? D2R is the bulb fitment type isn't it? Link to comment Share on other sites More sharing options...
maximase86 Posted October 14, 2006 Report Share Posted October 14, 2006 Unfortunately it doesn't have AMP connectors from what I can tell. D2R is the bulb type. The kit I bought was rebased for 9006.S Link to comment Share on other sites More sharing options...
prasamin Posted October 14, 2006 Report Share Posted October 14, 2006 Question, currently I run rebased D2R bulbs. They run off Denso OEM ballasts. Can I get bulbs compatiable with this type of ballast that will fit 9006? I really would like to get 6000k bulbs if I can.Sthere are adapters that go from the AMP connectors and daisy chain on to convert to D2R/D2S. I'm pretty sure I've seen the reverse also, but not sure.also, I got my H3 kit in today, and it seems like there will be some cutting involved to run the wiring through the back of the housing cap.anyone have some bright ideas for installing the ApexCone HID's in the 850 fogs? Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted October 14, 2006 Report Share Posted October 14, 2006 there are adapters that go from the AMP connectors and daisy chain on to convert to D2R/D2S. I'm pretty sure I've seen the reverse also, but not sure.also, I got my H3 kit in today, and it seems like there will be some cutting involved to run the wiring through the back of the housing cap.anyone have some bright ideas for installing the ApexCone HID's in the 850 fogs?yeah, cutting a whole in the cap for the fogs, its the only way. Link to comment Share on other sites More sharing options...
prasamin Posted October 14, 2006 Report Share Posted October 14, 2006 yeah, cutting a whole in the cap for the fogs, its the only way. i hate doing more work than necessary, especially when it takes me an hour just to get teh car jacked up Link to comment Share on other sites More sharing options...
the underlørd Posted October 14, 2006 Report Share Posted October 14, 2006 yeah, cutting a whole in the cap for the fogs, its the only way. yup, takes a lil modification, try parking on a incline, that's how i got to mine without having to jack the car up. Link to comment Share on other sites More sharing options...
prasamin Posted October 14, 2006 Report Share Posted October 14, 2006 yup, takes a lil modification, try parking on a incline, that's how i got to mine without having to jack the car up.did the cap go back on without issue? the extension on the back of the bulb looks long, so I dont know if the cap will close over it....and how did you reseal the back of the cap....i'm pretty sure your fogs are a bit different, so I dont know if this applies to you. Link to comment Share on other sites More sharing options...
the underlørd Posted October 14, 2006 Report Share Posted October 14, 2006 did the cap go back on without issue? the extension on the back of the bulb looks long, so I dont know if the cap will close over it....and how did you reseal the back of the cap....i'm pretty sure your fogs are a bit different, so I dont know if this applies to you. ya, i was thinking the same thing. on mine, the bulb holder came out, and it all got bored out, so uhh yeah.. Link to comment Share on other sites More sharing options...
leurven Posted October 17, 2006 Author Report Share Posted October 17, 2006 My supplier now has a good stock of 3000K kits if anyone is looking. These will give you a yellow look which is ofen used for the fog lights. Link to comment Share on other sites More sharing options...
