Trunks850R Posted August 4, 2006 Report Share Posted August 4, 2006 k im tryin to charge my ac system, but i think the compressor isnt coming on because i lt it get so low. its tellin me to jump off the low pressure cycling switch. where is it iat? when i find it what do i do then?help me out guys, thanks Link to comment Share on other sites More sharing options...
maiku Posted August 4, 2006 Report Share Posted August 4, 2006 it's behind the passenger headlightthe cap on the hose says 6 Nm Link to comment Share on other sites More sharing options...
Trunks850R Posted August 4, 2006 Author Report Share Posted August 4, 2006 it's behind the passenger headlightthe cap on the hose says 6 Nmyeah thats where im tryin to fill it at, but the book is tellin me taht i have to use a jump wire on it to gt the compressor to turn on so i can charge it. are we on the same page?? Link to comment Share on other sites More sharing options...
prasamin Posted August 4, 2006 Report Share Posted August 4, 2006 it's behind the passenger headlightthe cap on the hose says 6 Nmno it's not.the switch is on the pipe going into the firewall next to the pass side strut tower....it's a little harness plugged into the A/C line.....take that harness off, jumper it, and the compressor will turn on. Link to comment Share on other sites More sharing options...
Trunks850R Posted August 4, 2006 Author Report Share Posted August 4, 2006 "your compressor may cycle off if the pressure is low duu toa low charge. if the clutch cycles off, you can pull the low pressure cycling switch plug and attach a jumper wire, this will keep the compressor on" where is this "switch" Link to comment Share on other sites More sharing options...
prasamin Posted August 4, 2006 Report Share Posted August 4, 2006 "your compressor may cycle off if the pressure is low duu toa low charge. if the clutch cycles off, you can pull the low pressure cycling switch plug and attach a jumper wire, this will keep the compressor on" where is this "switch"jesus, did I not just tell you...that wiring harness IS the switch. take it off, and put a paper clip in it...one end going to one side of the connector and the other side of the clip on the other side of the connector (by connector I mean the part of the harness that's in your hand when you take it off).I just did this in my car. Link to comment Share on other sites More sharing options...
Trunks850R Posted August 4, 2006 Author Report Share Posted August 4, 2006 jesus, did I not just tell you...that wiring harness IS the switch. take it off, and put a paper clip in it...one end going to one side of the connector and the other side of the clip on the other side of the connector (by connector I mean the part of the harness that's in your hand when you take it off).I just did this in my car.damn dial up bullshit......your first post wasnt on there when i started that last one pras............but hell yeah thanks Link to comment Share on other sites More sharing options...
MadeInJapan Posted August 5, 2006 Report Share Posted August 5, 2006 Hey dude...Travis. You should have called me. I'm on Summer vacation now until the end of the month so I would have come over and done it for you, got all the gauges, etc. for A/C... Call me though if you have any other woes, or even if you don't. by the way, you left 'Ole Franklin? Where the hell you working at now? Link to comment Share on other sites More sharing options...
Trunks850R Posted August 5, 2006 Author Report Share Posted August 5, 2006 STILL cant get it to come one. i put a paper clip to it, and nothing happened. grrrrrrrrr i was gettin ready to sell this one too, but thats gonna be hard as hell without AC. anyways ill play with it somemore when i get home. oh and i hooked up a gauge to the low side, and it read into the danger zone right off the bat, so im starting to wonder. i think it might have done that though because i was able to feed about half a can of R134a into it prior to that. damn guys the bad thing is, i did like 15 retro fit jobs on cars with r12 back when i was in tech school. i swear learning to work on cars IS NOT like learning to ride a bike!oh and david, im at ted russell kingston pike now, ted finally got his way and got me back up here! Link to comment Share on other sites More sharing options...
prasamin Posted August 5, 2006 Report Share Posted August 5, 2006 so you jumpered that harness, and no cycling of the clutch?so you've either over charged or your compressor met the grave. Link to comment Share on other sites More sharing options...
MadeInJapan Posted August 6, 2006 Report Share Posted August 6, 2006 Trav...I'll have to come and see you.by the way, the pressure is going to read way in the red without the compressor running. That's normal. Link to comment Share on other sites More sharing options...
drlava Posted August 6, 2006 Report Share Posted August 6, 2006 if your compressor hasn't run for a while it could just be that the clutch is stuck, or the relay needs to be replaced. Link to comment Share on other sites More sharing options...
Uncle Boost Posted August 7, 2006 Report Share Posted August 7, 2006 jesus, did I not just tell you...that wiring harness IS the switch. take it off, and put a paper clip in it...one end going to one side of the connector and the other side of the clip on the other side of the connector (by connector I mean the part of the harness that's in your hand when you take it off).I just did this in my car.^^^ Thas funny as H3LL !! :lol: Link to comment Share on other sites More sharing options...
Uncle Boost Posted August 7, 2006 Report Share Posted August 7, 2006 STILL cant get it to come one. i put a paper clip to it, and nothing happened. grrrrrrrrr i was gettin ready to sell this one too, but thats gonna be hard as hell without AC. anyways ill play with it somemore when i get home. oh and i hooked up a gauge to the low side, and it read into the danger zone right off the bat, so im starting to wonder. i think it might have done that though because i was able to feed about half a can of R134a into it prior to that. Darn guys the bad thing is, i did like 15 retro fit jobs on cars with r12 back when i was in tech school. i swear learning to work on cars IS NOT like learning to ride a bike!oh and david, im at ted russell kingston pike now, ted finally got his way and got me back up here!Still no Clutch Cycling?..Wire a Test light into the wire(s) that plug into the compressor. Jumper the Switch, If the light comes on, then you have a compressor Clutch issue. NO light, Check Fuses....Fuse good? Check for open wires (continuity). Link to comment Share on other sites More sharing options...
