DARKSIDE Posted August 7, 2006 Report Share Posted August 7, 2006 I bought an Intercooler from EST, but when I tried to install it, I noticed that the intercooler endplates weren't long enough to bolt on to the radiator. The holes were about 1/2" off.Anyone else have this problem? Link to comment Share on other sites More sharing options...
the underlørd Posted August 7, 2006 Report Share Posted August 7, 2006 drill new holes? Link to comment Share on other sites More sharing options...
Gioseppe Posted August 7, 2006 Report Share Posted August 7, 2006 drill new holes? i don't even have one and i know you have to drill new holes! Link to comment Share on other sites More sharing options...
the underlørd Posted August 7, 2006 Report Share Posted August 7, 2006 http://volvospeed.com/vs_forum/index.php?showtopic=32625:) Link to comment Share on other sites More sharing options...
PullMyFinger Posted August 7, 2006 Report Share Posted August 7, 2006 I drilled holes too. In fact, mine didn't have *any* holes if I remember correctly. I bought mine 2 years ago though, different run... Link to comment Share on other sites More sharing options...
Zappo Posted August 7, 2006 Report Share Posted August 7, 2006 drill new holes? The EST ones come pre-drilled, unlike ours were we had to drill our own.I have heard of similar problems with the EST intercooler. Alignment just isn't right, so just drill new holes to make it fit. Link to comment Share on other sites More sharing options...
prasamin Posted August 8, 2006 Report Share Posted August 8, 2006 i got one mocked off of the A-tech...holes didn't line up perfectly, but close enough on most of them..... Link to comment Share on other sites More sharing options...
DARKSIDE Posted August 8, 2006 Author Report Share Posted August 8, 2006 Problem is:The intercooler measures 26 3/4" (taking into consideration the endplates), but the radiator measures 27 1/4". So I can't just drill extra holes because the holes on the radiator are basically at the tip of the endplate on the intercooler if that makes any sense...So the only option seems to be to weld a piece on to the one of the endplates on the intercooler. Link to comment Share on other sites More sharing options...
prasamin Posted August 8, 2006 Report Share Posted August 8, 2006 Problem is:The intercooler measures 26 3/4" (taking into consideration the endplates), but the radiator measures 27 1/4". So I can't just drill extra holes because the holes on the radiator are basically at the tip of the endplate on the intercooler if that makes any sense...So the only option seems to be to weld a piece on to the one of the endplates on the intercooler.oh shit, forget that....i would send that back or ask Frank to send you another one that is the right length. Link to comment Share on other sites More sharing options...
JoshV70 Posted August 8, 2006 Report Share Posted August 8, 2006 Link to comment Share on other sites More sharing options...
prasamin Posted August 8, 2006 Report Share Posted August 8, 2006 dude, is that safe? looks like it can slip left or right at any given moment and slide down! Link to comment Share on other sites More sharing options...
mike850r Posted August 8, 2006 Report Share Posted August 8, 2006 what about fabing up a bracket that bolts to the radiator with an offset stud comming up and putting a nut on it to hold the intercooler in place Link to comment Share on other sites More sharing options...
Gioseppe Posted August 8, 2006 Report Share Posted August 8, 2006 dude, is that safe? looks like it can slip left or right at any given moment and slide down! pras! remeber that the intercooler is part of a tasty sammich! i doubt it would move much....... Link to comment Share on other sites More sharing options...
BlackT5 Posted August 8, 2006 Report Share Posted August 8, 2006 and how much did you pay for the IC? Link to comment Share on other sites More sharing options...
DARKSIDE Posted August 8, 2006 Author Report Share Posted August 8, 2006 Josh it seems like you have the same problem with your intercooler...After some thought:I think the best solution is to cut (straight down) half of one of the endplates, weld on a piece that just 1/2" wider, and drill the neccesary holes...that should do it...I'm frustrated right now...tired of everything not fitting like it should, after paying sooo much 4 the freakin' part... Link to comment Share on other sites More sharing options...
