SkyWriter Posted August 28, 2006 Report Share Posted August 28, 2006 I just got my AT cooler installed. not available from Volvo in the US; this OEM part is nonetheless a drop in upgrade for domestic models. also painted my grill up, and got my EVOLVE front endlinks replaced with QuickBrickMotorsports (like the rear). suspension is nice and tight again! Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 28, 2006 Report Share Posted August 28, 2006 Part #? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 28, 2006 Report Share Posted August 28, 2006 Part #?9499131 FCPgroton usually has it in stock. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 28, 2006 Report Share Posted August 28, 2006 9499131 FCPgroton usually has it in stock. Same one as S70 for S80? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 28, 2006 Report Share Posted August 28, 2006 Same one as S70 for S80?Should be.U-haul sells a kit also Link to comment Share on other sites More sharing options...
Mesoam Posted August 28, 2006 Report Share Posted August 28, 2006 price? a good B&M install should run about $150 max (i'm not talking home depot fittings ) Link to comment Share on other sites More sharing options...
the underlørd Posted August 28, 2006 Report Share Posted August 28, 2006 wow! old news rocks! Link to comment Share on other sites More sharing options...
RussB Posted August 28, 2006 Report Share Posted August 28, 2006 but did you really pay $880 for it from ViVa?! Link to comment Share on other sites More sharing options...
George @ ViVA Posted August 29, 2006 Report Share Posted August 29, 2006 9499131 FCPgroton usually has it in stock.That's not the correct PN that Volvo publishes for the S80 transmission cooler Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 29, 2006 Report Share Posted August 29, 2006 That's not the correct PN that Volvo publishes for the S80 transmission coolerOk whats the right one so I do not have to cross reference and we can by pass you? :lol: Link to comment Share on other sites More sharing options...
leurven Posted August 29, 2006 Report Share Posted August 29, 2006 What was wrong with your evolve endlinks? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 29, 2006 Report Share Posted August 29, 2006 but did you really pay $880 for it from ViVa?!Holy shit. I thought you were joking. George is out of his freaken mind for even stocking a part with that much markup. I mean I am all for OEM, but thats 60 dollars in parts. Even trippled keyed would be 180. Link to comment Share on other sites More sharing options...
SkyWriter Posted August 29, 2006 Author Report Share Posted August 29, 2006 What was wrong with your evolve endlinks?the rear set didn't fit the P2 suspension correctly, you couldn't set then so they didn't rub against the lower control arm. luckily the aluminum shaved off quickly. i replaced those several months ago.on the front ones the hiem joints loosened up and started clicking. once they were replaced with the QBM endlinks the suspension is much tighter. the evolves were tight in the begining, but they just didn't last. i've only had them on for 8 months or so. Link to comment Share on other sites More sharing options...
PullMyFinger Posted August 29, 2006 Report Share Posted August 29, 2006 Jeezus, get a B&M with swegged lines for under a hundred. Link to comment Share on other sites More sharing options...
RussB Posted August 29, 2006 Report Share Posted August 29, 2006 the rear set didn't fit the P2 suspension correctly, you couldn't set then so they didn't rub against the lower control arm. luckily the aluminum shaved off quickly. i replaced those several months ago.on the front ones the hiem joints loosened up and started clicking. once they were replaced with the QBM endlinks the suspension is much tighter. the evolves were tight in the begining, but they just didn't last. i've only had them on for 8 months or so.never mind all that, did you really pay $880 (or anywhere around that) for the A/T cooler? :o Link to comment Share on other sites More sharing options...
