Yellow95 Posted October 15, 2006 Report Share Posted October 15, 2006 Please give me a quick yes or no.Gary Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 15, 2006 Report Share Posted October 15, 2006 Yes Link to comment Share on other sites More sharing options...
hawks25 Posted October 15, 2006 Report Share Posted October 15, 2006 Yes, momentarily, until the ECU backs it down. At least that's how I understand it.edit: anal about punctuation. Link to comment Share on other sites More sharing options...
Yellow95 Posted October 15, 2006 Author Report Share Posted October 15, 2006 My ECU has no idea what boost i am running.Gary Link to comment Share on other sites More sharing options...
854TGA+ Posted October 16, 2006 Report Share Posted October 16, 2006 Don't do it. Not a good thing to mess with...... Link to comment Share on other sites More sharing options...
ViperVette Posted October 16, 2006 Report Share Posted October 16, 2006 Yes, but be very careful. Really easy way to cause some major problems. Link to comment Share on other sites More sharing options...
Seamus Posted October 16, 2006 Report Share Posted October 16, 2006 NO! Not exactly! IPD had a tutorial on how to properly set up the WG. I would suggest looking at that and get a calibrated low pressure gauge to check it out.. Link to comment Share on other sites More sharing options...
550 Posted October 16, 2006 Report Share Posted October 16, 2006 Dave only the newer cars will do that. I believe your Wastegate should be at around 7 psi. Be careful when you do this. What happens is if you have it set too low it will exhuast the gas spinning the compressor sooner so you wont make as much pressure. When you tighten the rod it will not exhuast the gas until later due to the more tension on the rod. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted October 16, 2006 Report Share Posted October 16, 2006 NO! Not exactly! IPD had a tutorial on how to properly set up the WG. I would suggest looking at that and get a calibrated low pressure gauge to check it out..+1. Overall best setting. Link to comment Share on other sites More sharing options...
hawks25 Posted October 17, 2006 Report Share Posted October 17, 2006 +1. Overall best setting.In the IPD instructions, it states that the stock setting is 1-3psi (If I Recall Correctly) and they recommend setting it to 5-7psi. Which would you (all) consider the "best setting"? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 17, 2006 Report Share Posted October 17, 2006 3.1-4.9 I've always just set it around half my max boost.FWIW, Johann has recommended doing the same in the past. Link to comment Share on other sites More sharing options...
Seamus Posted October 17, 2006 Report Share Posted October 17, 2006 The 5-7 works great but I challenge you to find a gauge that is that accurate that low a pressure, hence the broad tolerance. If you adjust it you can get it into the ballpark and try a turn or two to fine-tune it. The first thing that will happen is the engine will pre-detonate at low RPMs and the ecu will not be able to dump the boost fast enough. This will turn on a check engine light on giving you a boost control code. Link to comment Share on other sites More sharing options...
TorqueSteer Posted October 17, 2006 Report Share Posted October 17, 2006 Meh Ive always had it as tight as it can go, used with an MBC and bypassing the BCS, never had any problems. With the MBC settings left the same, tightening the wastegate arm will increase max boost with each turn. Link to comment Share on other sites More sharing options...
HoustonT5-R Posted October 17, 2006 Report Share Posted October 17, 2006 I've had the arm shortened pretty much all the way since I put my 16T on in May and have had zero problems with it. Before that, I was running my 15G the same way with no problems. Oh yeah, I'm still using the stock BCS and no MBC. Link to comment Share on other sites More sharing options...
hawks25 Posted October 17, 2006 Report Share Posted October 17, 2006 Joe, you sure it's 3.1 and not 3.3? I'm certain there isn't a gauge that is super accurate, but in reality, I really was looking for a range. Since it came up, what a perfect opportunity to ask. If I have mine set around 7psi, I get crazy boost spikes up to 21psi in between shifts (auto). The ECU catches it, but it feels like I lose performance (maybe timing pull) while it gets the boost back under control. The 21psi part is what scares me. Any higher and I think I'll start having palpitations.Meh...what I really need is to get this thing tuned. Link to comment Share on other sites More sharing options...
