Posted (edited)
EDIT: My thread was neutered during the unarchiving process, so half of it is gone.. I've updated the first post with some pics. Latest upgrades start on page 17/18
Click here for the latest
My setup started out with a 19T, BSR downpipe. BSR exhaust and Upsolute tune from Bill@adrenaline racing. This lasted just over a month before a few rods bent from detonation. I had a local machine shop tear the motor down and install VMS rods and pistons (I was one of Terry's first customers) I sent the head out to get ported/polished, 3 angle valve job, etc..
I ran the built motor with the same 19T, exhaust and tune I had before but never heard the sound of detonation. I beat the shit outta this thing for almost 3 years but I wanted more.
The newest setup:
1998 B5234T3
Eagle rods
Ross pistons
Balanced rotating assembly
Arp headstuds
Ported/polished head
3 angle valve job
Catcams camshafts
Autotech racing valve springs
Coil on plug conversion
850 T5-R flywheel
Spec stage 3+ clutch
Quaife LSD
Race Lab tubular exhaust manifold
GT35R (T3 0.82/.70 A/R)
Tial 44mm wastegate
Tial 50mm blow off valve
Precision 600hp intercooler
NA throttlebody
2.5" intercooler piping
3" turbo back exhaust
Siemens 875cc injectors - Upgrading to ID1000s
Walbro 255lph
Fuelab 10 micron filter
PTFE -6 fuel lines to tank
Aeromotive FPR
S60R fuel rail
DO88 aluminum radiator
Custom external oil cooler
Nira i3+ EMS
KW v2 coilovers
IPD sway bars
OMP strut brace
Rear upper shock brace
S60R caliper coversion front & rear
330mm rotors all around
GReddy Boost gauge
GReddy Oil pressure gauge
Innovate LC-1 Wideband o2
V70R door panels
V70R instrument cluster
04 C70 Jewel headlights & corners
V70R front bumper
STI front lip
Mirzam 18x8" wheels
235/40R18
10mm spacers front
20mm spacers rear
a few pics from the build..
The car is off the road for the winter turbo upgrade http://volvospeed.com/vs_forum/public/style_emoticons/#EMO_DIR#/biggrin.gif
19T was the first to come off, as was the stock IC and the BSR exhaust.
19T and GT35R:
Precision intercooler mocked up:
S60R manifold and new turbo mocked up. The turbo will end up sitting higher as I only had 8mm studs to mount it and the hole in the turbine flange and a fair size larger.
It's close to the mount, but like i said, it will sit a bit higher after final install.
I had originally planned on having a tubular exhuast manifold made, but ended up using the S60R manifold to save myself some headaches. I still wanted to run the external wastegate so I switched over to a 5 bolt turbine.
4 bolt:
5 bolt:
Installed the Innovate WB02 and XD16 gauge:
Siemens 630cc injectors:
New coolant lines and fittings:
GT install kit. I'm hoping I will luck out and be able to use the stock return line, but we'll see.
Oil feed setup:
Next step is to run the IC piping and drop in the NA cams. The 3" exhaust/external wastegate setup is being fabbed locally after I get all this other stuff done.
Tuning.. yes I know someone's going to ask... is still up in the air. Nira is a possibility if the budget permits.
I currently have a dualmass flywheel and spec stage III clutch installed. I have purchased a T5R singlemass flywheel but am still on the hunt for a good clutch. I will stick with the dualmass for a while and just keep the boost down until I can find a clutch and get my hands on a LSD. That way, it can all be done at once and then I can crank the boost up.
Updating this with some new pics since the last half of my thread got lost. :(
Edited by BlackT5
  • Upvote 2
Mark, I feel like you are my brother in some way haha.
Except my rod bender was a 16t and I have a high compression engine :(
I'm scared...
Ur not the only one, can't wait to see what type of numbers this beast puts out after the install...
  • Downvote 1
Ah, one of, if not the biggest reasons I got the black T5M is now going to convert itself into a beast. Mark, best of luck with everything! Looking good, big man, looking good.
Thanks for the shoutout. :)
I'm scared...
Me too. That turbo is fricking awesome. My buddy just put it on his maxima and it hauls ass. Wow!! Good luck man. Can't wait to see the final and the dyno results.
looks good mark but please do not use those cheapy "AN look" clamps
What are you doing for a winter ride?
The collar/clamps look alright if done correctly. It's either just a hose clamp, or i put the collar on.. i'm going to put the collar on.
winter ride is a Honda crx
Guest
Reply to this topic...
  Only 75 emoji are allowed.
