Yea man, i'm sure you could relocate it.
Wait, I thought you already did your FMIC?
I did, i'm redoing my piping because I don't like the way the cold side was done due to the airpump. Also doing 2.25 hot side.
good god that IS rediculously tight.
That's why I stepped down to 2.25 from 2.5". I pushes on the coolant lines, and oil cooler lines and was causing some minor leaks. It's just too tight IMO.
yup, better safe than sorry....it may be okay if it touches the lines, but any pressure against the oil or coolant lines, and you're going to stress them out, and over time, they will fail.
I have my lower I/C pipe touching my lower coolant line as it comes up to the throttle, so I wrapped it in rubber at that portion so the steel doesn't wear through the rubber on the coolant line. It should hold fine.
Guest S7013g
I haven't been reading this thread for awhile now.
Wow it looks great!
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
