Über855R Posted January 6, 2007 Report Posted January 6, 2007 Cool, great build so far. Any idea what kind of power you made on that 19t after the motor build and before deciding to upgrade? What kind of boost were you running on the 19t? That garrett turbo is HUGE! Can't wait to see this bad azz mo fo back on the road. :) Quote
BlackT5 Posted January 6, 2007 Author Report Posted January 6, 2007 Cool, great build so far. Any idea what kind of power you made on that 19t after the motor build and before deciding to upgrade? What kind of boost were you running on the 19t? That garrett turbo is HUGE! Can't wait to see this bad azz mo fo back on the road. 19psiI think i should be able to make around the same power on 1/2 the boost with the new setup. The powerband should be much better also. Quote
ACES70 Posted January 6, 2007 Report Posted January 6, 2007 19psiI think i should be able to make around the same power on 1/2 the boost with the new setup. The powerband should be much better also.Yikes, freakin yikes. Makes me want to get a T5 and just go with your past setup. Quote
narxs70 Posted January 6, 2007 Report Posted January 6, 2007 ditto. i can't wait to see this monster. this build is aawesome. thanks for the update. this tops off and already good day for me. Quote
550 Posted January 7, 2007 Report Posted January 7, 2007 Mark, I feel you on the seeing your car sitting there thing it sucks. Quote
BlackT5 Posted January 7, 2007 Author Report Posted January 7, 2007 I forgot to take pics of the cam cover ready to go in with the cams installed but they're in.I quickly made my own cam locking tool and it was worth it. Much easier to have the cams held steady while your trying to bolt it back up. It also stops the cams from moving while you install the cam gears and slip on the timing belt. Pretty hard to mess things up this way. Anyone doing cam swaps, i highly recommend you make oneof these. Took all of 15 mins.the toolcam gears on, timing belt tensionedput on a few things last night.. S60R mani is in place, just need some more studs and then the turbos going on.after that, the next job is IC piping Quote
Mesoam Posted January 7, 2007 Report Posted January 7, 2007 no catch can, come on you know you want to... Quote
BlackT5 Posted January 7, 2007 Author Report Posted January 7, 2007 no catch can, come on you know you want to...Catch can is on the list, just gotta choose how i'm going to run it. ;) Quote
prasamin Posted January 7, 2007 Report Posted January 7, 2007 have you ever replaced the knock sensors? Quote
BlackT5 Posted January 8, 2007 Author Report Posted January 8, 2007 have you ever replaced the knock sensors?nope.why? Quote
NGB Posted January 8, 2007 Report Posted January 8, 2007 Can't wait to see that turbo bolted up Keep the pics coming. Quote
RedspeedR Posted January 18, 2007 Report Posted January 18, 2007 Holy crap!...good job.Jason :ph34r: Quote
Gioseppe Posted January 18, 2007 Report Posted January 18, 2007 the 10 day update, what's the word? 1 Quote
