Manual Swap Parts Bible
prasamin
Just an update: I found the part number for the center console bezel for a 98 V70: There are a number of different colors available of course but the one that matches my interior and I imagine most normal interiors is called "plastic" and it's number is: 9192844
Cost of the part is in the realm of $45-50 new.
oh man, I completely forgot about getting the pn for you. glad you found it!
  • Replies 43
God I love VS. Only VS could someone actually walk you step to step in a manual conversion. Thanks Pras, if I ever use it in the future, haha.
~Mike
Yes the tranny will work on your 98 S70. Assuming you're in the US where those didn't come in a manual trans you are looking to do a swap correct?
Good luck. Merry Christmas everyone.
the 98 S70 didnt come in a 5spd? ummm idono if im on the same page here... 98 S70 T5M FTW!
My .02 cents.
Parts sources:
Clutch master cylinder: Eeuroparts. ~ $100
Slave cylinder: Myswedishparts.com ~ $50
R clutch: Fcp groton ~ $300
Throwout bearing: Myswedishparts.com ~ $45
Shifter cables (if needed): Myswedishparts.com ~ $100
Clutch hose: (buy new) Myswedishparts.com~ $50
You can reuse the flywheel bolts if they look to be in good shape, and look like they haven't been out before. Mine were perfect just reinstall with a little locktite.
Pressure plate bolts are cheap and you can buy them at Napa. do it.
Use Mobil 1 or similar 75-90 gear oil, don't waste your money on the Volvo oil
Make sure you resurface the flywheel, all else Pras already explained.
:D
He said an "S70 GLT"
Therefore it did not come in a 5spd in the U.S. since that is a LPT.
In my book the only reason to even bother with a manual swap is if they were never made, like the 850s in the States... It would be cheaper and easyer to just sell a GLT and buy a T5M
~Mike
http://volvospeed.com/vs_forum/index.php?s...c=25957&hl=
did my swap with play by play as i was doing it over july 4th weekend 2005.
still got some pics too of the flywheels. did not know about the engine sensor thingy. i never reverse the polarity and my car is running since 7-05-2005.
here are the pics of old and "new" used flywheel
flywheel pic
