'93 Dave Posted February 15, 2008 Report Share Posted February 15, 2008 mmmmmmmmmmminspirational to me B) Link to comment Share on other sites More sharing options...
Raintracks Posted February 15, 2008 Report Share Posted February 15, 2008 which rims are those?i has liked it Link to comment Share on other sites More sharing options...
Plan_B Posted February 15, 2008 Report Share Posted February 15, 2008 Why? Still here.When I am uber bored I watch it, it's pretty cool.creeeepy......................Why is it creepy?, it's pretty cool actually and besides it's not like I installed it :monkey: Link to comment Share on other sites More sharing options...
Nader Posted February 15, 2008 Report Share Posted February 15, 2008 QUOTE (Plan_B @ Feb 15 2008, 02:52 PM) <{POST_SNAPBACK}>When I am uber bored I watch it, it's pretty cool.Why is it creepy?, it's pretty cool actually and besides it's not like I installed it We all know the only reason you watch is because you want to see some of this! Link to comment Share on other sites More sharing options...
Plan_B Posted February 15, 2008 Report Share Posted February 15, 2008 We all know the only reason you watch is because you want to see some of this!Ummmmmm...weird that you have that image on your computer ;) Link to comment Share on other sites More sharing options...
Johann Posted February 16, 2008 Author Report Share Posted February 16, 2008 As you can see the webcam offers a wide variety of interests.. One of my fav's, Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted February 17, 2008 Report Share Posted February 17, 2008 Webcam bookmarked. Link to comment Share on other sites More sharing options...
R o b Posted February 27, 2008 Report Share Posted February 27, 2008 Great picture Johann!As some say in Holland:"Jong geleerd is oud gedaan"! Link to comment Share on other sites More sharing options...
volvorsport Posted March 3, 2008 Report Share Posted March 3, 2008 hey johann ,we should bang heads - did you make that manifold or buy it off jenvey ?i think weve got the other one here - im building a NASP to ggo in my kitcar - redblock turbo was too brutal .weve sourced billet flywheels , the iTBs , cam shafts from catcams , were just working on heads at the moment .weve also decided that for road/rally use we can go to 2.5 and keep the revs down , or use a 2 litre crank and redblock conrods for about 9500rpm .im on the lookout for later heads with solid followers to convert earlier heads , BUT , they all seem to be VVT which has nacked the plan up .what HP do you think youll get to on std cams /head ? Link to comment Share on other sites More sharing options...
Johann Posted March 3, 2008 Author Report Share Posted March 3, 2008 The manifold was made at our company.I posted about it here.If you have a Jenvey manifold I'm 99.5% positive it is for the newer style heads and uses different port shape. Link to comment Share on other sites More sharing options...
volvorsport Posted March 3, 2008 Report Share Posted March 3, 2008 The manifold was made at our company.I posted about it here.If you have a Jenvey manifold I'm 99.5% positive it is for the newer style heads and uses different port shape.yes it is , but im building one with an earlier head like yours !i wanted to originally build it so i could use the solid followers - but obviously thats going to mean a later head , which i do have .Another question , did they enlarge to 32mm inlets ? cos i havent found one yet either . Link to comment Share on other sites More sharing options...
Johann Posted March 3, 2008 Author Report Share Posted March 3, 2008 yes it is , but im building one with an earlier head like yours !i wanted to originally build it so i could use the solid followers - but obviously thats going to mean a later head , which i do have .Another question , did they enlarge to 32mm inlets ? cos i havent found one yet either .The valves you mean? They are all the same size from 92 all the way up to present day. Only difference in the diameter of the valve stem which changed from 7 mm to 6 mm in de newer VVT engine's.If you do not have cams now and have the manifold already then go for a new type head. The cams can't be used in both heads because they have a different placement of the axial bearing. If you special order cams you can revert back to non VVT and just block the oil provisioning on the cams cover. Link to comment Share on other sites More sharing options...
volvorsport Posted March 3, 2008 Report Share Posted March 3, 2008 thats interesting about the valve sizes - i have a manual indicating theyre 32mm for the later models .My VVT head though had hydraulic followers circa 2003What cams are you running ?how did you adjust the folllowers without the holes in the cam cover ! Link to comment Share on other sites More sharing options...
Johann Posted March 4, 2008 Author Report Share Posted March 4, 2008 Valves are 31 intake, 27 exhaust. later VVT isn't hydro as far as I'm aware, only very early '99 VVT heads had hydro lifters (Followers). For adjustment there is a special tool from Volvo which can be used to fix the cams. Link to comment Share on other sites More sharing options...
Johann Posted April 21, 2008 Author Report Share Posted April 21, 2008 April 19th the SDM passed it's annual inspection without remarks. Link to comment Share on other sites More sharing options...
