rexford310 Posted March 8, 2009 Report Share Posted March 8, 2009 and what was the time then? Link to comment Share on other sites More sharing options...
Emiel Posted March 8, 2009 Report Share Posted March 8, 2009 What a blast!!! SDM = Awesome! Link to comment Share on other sites More sharing options...
fearless Posted March 8, 2009 Report Share Posted March 8, 2009 SDM = Awesome!+1 B) Link to comment Share on other sites More sharing options...
Johann Posted March 8, 2009 Author Report Share Posted March 8, 2009 and what was the time then?2:15 ;) Link to comment Share on other sites More sharing options...
Johann Posted April 10, 2009 Author Report Share Posted April 10, 2009 Individual throttle bodies.That is incredible. I also want to hear a sound clip!http://www.youtube.com/watch?v=j_q3cTHAzDINice weather today. SDM needs some TLC, Link to comment Share on other sites More sharing options...
ozone_1974 Posted April 10, 2009 Report Share Posted April 10, 2009 Just saw the entire lap from withing the SDM on YouTube Johann ... AWESOME !!!! Link to comment Share on other sites More sharing options...
Silver854m56 Posted May 29, 2011 Report Share Posted May 29, 2011 <!--quoteo(post=885659:date=Jan 22 2007, 09:23 PM:name=BlackBeast)--><div class='quotetop'>QUOTE(BlackBeast @ Jan 22 2007, 09:23 PM) ←</div><div class='quotemain'><!--quotec-->So how did you go about getting rid of it? Exactly like Slater said in the PS thread?<!--QuoteEnd--></div><!--QuoteEEnd--> For now all lines have been removed. I still want to make a small breather box, let de lines run to it and hope it will work that way. Johann, I realize this is a pretty old blog... any chance you can still tell me where you got the front splitter for this beast? my proj is a '94 854 5spd and I've been looking for a splitter like the one you have on the SDM for a while and haven't found anything as nice as you've got. your car looks and sounds amazing. your 850 is my 850's role model. Friggin' awesome build. Link to comment Share on other sites More sharing options...
Johann Posted May 30, 2011 Author Report Share Posted May 30, 2011 I don't know if it is still available. Supplier is mentioned in this post, Edit: Realcar is still offering the splitter here. Link to comment Share on other sites More sharing options...
Johann Posted June 27, 2011 Author Report Share Posted June 27, 2011 Because people were asking, SDM engine spec, Block, B5244T3 block, crankshaft and rods (147 mm) All bearings used are turbo spec. Block machined 0.3 mm below OEM deck height, 0.4 mm overbore. B5244S 0.4 oversize Volvo OEM (Mahle) pistons and OEM piston rings. 21 mm diameter piston pin. B5244T3 head gasket was used. With CC'd head the compression came down to 11:1 Head, Very early 1992 B5254S head. Head has been converted to to 2001 type valves with the 6 mm valve stem. Slightly shortened valve guides to prevent binding on the valve seals. Solid valve lifter buckets instead of hydraulic with shorted stems using under-bucket shims for adjustment. Oil feed channels for hydro lifters have been blocked, Head machined near lifters to clear the cam lobes, Catcams double valve springs and custom retainers, Catcams steel cams 12.5 mm lift, duration undisclosed. Ports were only smoothened near the valve seats and intake ports were port matched to the intake bridge, Slightly lightened flywheel and 850R clutch kit are used. ITB setup, Jenvey SF45/1 throttle bodies, Intake bridge, Homebrew CNC machined, Port matched 3 mm base plate for the airbox was added, 90 mm stacks and some connections for idle regulation although not used at the moment, IAT sensor and for vacuum. Vacuum taken from each runner connected to a small canister to smoothen the vacuum erratic behavior. Although the EMS is operating in Alpha N mode it does use MAP for baro corrections. Airbox mainly shaped to available space with a repositioned radiator. Intake opening is near 95 mm. Jenvey throttle linkages were used in combination with the OEM Volvo throttle roller. Slightly altered OEM fuel rail with a firewall mounted pressure regulator operating at 58 psi. 395 CC injectors used. Walbro 255 lph in tank fuelpump New style thermostat housing was used with an extension to clear No.1 runner and TB. Exhaust, OEM NA exhaust manifold slightly ported, 2.5" exhaust, 100 CPI Kemira race cat and 2.5" Ferrita turbo catback. EMS, Linkplus G2 standalone, Sequential fuel and distributer ignition. Link to comment Share on other sites More sharing options...
Silver854m56 Posted September 13, 2011 Report Share Posted September 13, 2011 I don't know if it is still available. Supplier is mentioned in this post, Edit: Realcar is still offering the splitter here. Thanks! Now I just gotta learn Swedish... Link to comment Share on other sites More sharing options...
lookforjoe Posted September 13, 2011 Report Share Posted September 13, 2011 Impressive! What is the significance of the '92 head? I'm assuming it has some additional potential that makes it worth updating to newer style valves etc.., rather than just getting a newer head? Link to comment Share on other sites More sharing options...
scandalo Posted September 13, 2011 Report Share Posted September 13, 2011 Let me just pick my jaw up off the floor. This is going to sound SOOOOOOOOOOOO good! Link to comment Share on other sites More sharing options...
andyb5 Posted September 13, 2011 Report Share Posted September 13, 2011 Let me just pick my jaw up off the floor. This is going to sound SOOOOOOOOOOOO good! Yes, it already does Link to comment Share on other sites More sharing options...
scandalo Posted September 13, 2011 Report Share Posted September 13, 2011 mmmmmmm 7500 shifts. Glorious. I never knew this car was running ITBs until now. Link to comment Share on other sites More sharing options...
Johann Posted September 13, 2011 Author Report Share Posted September 13, 2011 Impressive! What is the significance of the '92 head? I'm assuming it has some additional potential that makes it worth updating to newer style valves etc.., rather than just getting a newer head? The idea was to use an 850 NA as a base and those cars come with the square port heads. The intake bridge was fabricated to fit this type of head. After the first engine broke I only wanted a somewhat stronger block but all other was basically OK. The choice for the high lift cams was mainly for sound but for this to happen we needed to convert to solid lifter bucket. Also a standard valve guide plus seal setup will bind near 11 mm lift so they needed a change anyway. Link to comment Share on other sites More sharing options...
