98Silver70 Posted November 25, 2007 Report Share Posted November 25, 2007 Just got mine in last night, they work fine and look awesome! Link to comment Share on other sites More sharing options...
TG850T5R Posted November 27, 2007 Report Share Posted November 27, 2007 I just put these in on Friday, and 2 nights ago the headlight went out. I switched bulbs and ballast's to see what was bad and now I need a new ballast! I JUST GOT THESE! Anybody else have a problem like this?Well............I just got mine in and installed it today.... Install was easy but when I turned on the headlights only one was working.... I rechecked the connections & etc and sure enough one bulb is not working..... I contacted Han and see what he says.... I was really looking forward to having these on the car..... Hopefully the replacement bulbs won't take a long time to get here. Link to comment Share on other sites More sharing options...
AntiHero Posted November 27, 2007 Report Share Posted November 27, 2007 Try the bulb on the other side with the working ballast. Ive been around HID's for a little while now and I KNOW they are a pain in the neck to deal with sometimes! I have HID lows and fogs on the M3 and every now and again id be driving down the street and hit a bump and one of the headlights would go out. I finally figured it out that the wiring was loose and would not make a connection when I hit the bumps. You also might have a bad ballast. I just hooked mine up last night to a battery charger to see if I could get it to work on that. When I try to start it the light just flickers a few times then shuts off immediately. Ive had this problem on the M3 as well and the last time this happened it was the ballast. So just make sure you double check and make sure you order the right thing. Well............I just got mine in and installed it today.... Install was easy but when I turned on the headlights only one was working.... I rechecked the connections & etc and sure enough one bulb is not working..... I contacted Han and see what he says.... I was really looking forward to having these on the car..... Hopefully the replacement bulbs won't take a long time to get here. Link to comment Share on other sites More sharing options...
TG850T5R Posted November 27, 2007 Report Share Posted November 27, 2007 Another Update.....Kit is working just fine. There was a little problem on the wiring of my car which I fixed. Han has been VERY responsive through out this and helpful. The bulbs, ballasts & etc is working just as they should..... Overall, I am very happy camper now Up Date:Well today after work I decided to go at it again.....(for almost 2 hours of testing) Reinstalled the kit with different variations..... this time I get NOTHING! Connections are fine, fuses are fine. I highly doubt the car ('97 Galant) the kit is going into is smart enough throw any ECU errors & etc.Any ideas..... ????? Is it possible that the whole kit is faulty..... Any suggestions to get this darn thing to work???Thank You..... Double checking the wiring was the 1st thing I did...... I then unplugged the bulb from the working side and installed the faulty bulb to working sides ballast......Still nothing..... The bulb itself looks just fine but I am quite sure it is the bulb.... Unless of course there is something else you suggest that I try I will have to cough up another $35.00 for a bulb since that appears to be the fastest way to get a replacement.....Also, the email I got from them suggests that I reverse the wires...... This thing is pretty idiot proof.... How is it possible to reverse the wires..... It looks as things can only go in one way...... Kinda confused there...... And trust me I am pretty good at dealing with this kinda stuff. And one last question that I have is..... how do I test the harness that is attached to the bulbs.... May be there is something wrong with the harness....Try the bulb on the other side with the working ballast. Ive been around HID's for a little while now and I KNOW they are a pain in the neck to deal with sometimes! I have HID lows and fogs on the M3 and every now and again id be driving down the street and hit a bump and one of the headlights would go out. I finally figured it out that the wiring was loose and would not make a connection when I hit the bumps. You also might have a bad ballast. I just hooked mine up last night to a battery charger to see if I could get it to work on that. When I try to start it the light just flickers a few times then shuts off immediately. Ive had this problem on the M3 as well and the last time this happened it was the ballast. So just make sure you double check and make sure you order the right thing. Link to comment Share on other sites More sharing options...
clarkerussell Posted December 13, 2007 Report Share Posted December 13, 2007 Hello,I just noticed that these HID's have causes static on my radio when they are on. I have a factory stereo in my 1998 S70. Has anyone else experienced this?Clarke Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted December 13, 2007 Report Share Posted December 13, 2007 Hello,I just noticed that these HID's have causes static on my radio when they are on. I have a factory stereo in my 1998 S70. Has anyone else experienced this?Clarkemine do this as well, but only on low beams, the fog HIDs dont do this, i was told its a bad ground somewhere, so im not sure its the HIDs fault yet. Link to comment Share on other sites More sharing options...
98Silver70 Posted December 13, 2007 Report Share Posted December 13, 2007 mine do this as well, but only on low beams, the fog HIDs dont do this, i was told its a bad ground somewhere, so im not sure its the HIDs fault yet.sorry, unrelated, but you have HID fogs? they're h1 right? how exactly to you put an hid kit into a h1 light, i just looked at my fogs and it looks like it wouldn't be as easy as h7s Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted December 13, 2007 Report Share Posted December 13, 2007 sorry, unrelated, but you have HID fogs? they're h1 right? how exactly to you put an hid kit into a h1 light, i just looked at my fogs and it looks like it wouldn't be as easy as h7si actually have h3, but im not sure how its any different. Same deal, drill hole in the cap, plug in, mount ballast up by the sides of the bumper, fit all the cords inside without clamping any down, and turn on. What problem do you forsee? Link to comment Share on other sites More sharing options...
'93 Dave Posted December 13, 2007 Report Share Posted December 13, 2007 i actually have h3, but im not sure how its any different. Same deal, drill hole in the cap, plug in, mount ballast up by the sides of the bumper, fit all the cords inside without clamping any down, and turn on. What problem do you forsee?bulbs being to long Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted December 14, 2007 Report Share Posted December 14, 2007 i know there are people with HID fogs with x70s. Link to comment Share on other sites More sharing options...
98Silver70 Posted December 14, 2007 Report Share Posted December 14, 2007 well i'm pretty sure the 70 series have h1 fogs and the wiring harness is much different than an h7, just seems like it will be harder to then my h7s Link to comment Share on other sites More sharing options...
sweeedespeed Posted December 28, 2007 Report Share Posted December 28, 2007 How much for 4300K Bulbs? They have the most lumens don't they? Link to comment Share on other sites More sharing options...
Dmsee Posted December 28, 2007 Report Share Posted December 28, 2007 Check the website Link to comment Share on other sites More sharing options...
'93 Dave Posted December 28, 2007 Report Share Posted December 28, 2007 thread keeps coming back from the dead, ohh yea its close to a year since ive had my ballasts and they still work perfectly, even with d2s bulbs Link to comment Share on other sites More sharing options...
C70drvr Posted December 31, 2007 Report Share Posted December 31, 2007 Just ordered a set of 6000K replacement bulbs. Link to comment Share on other sites More sharing options...
