necvolvo Posted January 28, 2007 Report Share Posted January 28, 2007 got 0422 code for cat eff. new o2 sensors, new cat, no vac leak, fuel pressure good ,no leaks in freash air intak, no exhuast leaks, comes on right when drive cycle is complete ,after market cat but i've used them before successfully. is this a false code? does the ECU need to be cleared and reprogrammed/adapted, i don't have a tech five and the dealer will probably say it needs a new engine to make the light go away this car runs great but the customer is CEL paranoid AGHHHHHH! Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted January 28, 2007 Report Share Posted January 28, 2007 Try pullin your ECU out for about ten minutes to reset the adaptives. Link to comment Share on other sites More sharing options...
MrWinkey Posted January 28, 2007 Report Share Posted January 28, 2007 Reseting the adaptives may correct it. If not it is probably the aftermarket cat at fault. See what the front and rear 0/2's are reading . Did you use OEM 0/2's. 0422 is set when your 0/2 values between each other are not correct. Rear 0/2 could be the cause but more than likely it's the cat as long as there are no other codes present. Link to comment Share on other sites More sharing options...
necvolvo Posted January 28, 2007 Author Report Share Posted January 28, 2007 Reseting the adaptives may correct it. If not it is probably the aftermarket cat at fault. See what the front and rear 0/2's are reading . Did you use OEM 0/2's. 0422 is set when your 0/2 values between each other are not correct. Rear 0/2 could be the cause but more than likely it's the cat as long as there are no other codes present.New OEM o2's didn't have tool to pop out ECM but I shorted the batt terminals together for about 10min and no luck. I even placed the rear 02 out of the direct stream (used an 18mm sparkplug anti-fouling bushing) to try and fool the ecm and no luck. I'll have volvo attempt adaptive reset this week but I'm leaning torwards the aftermarket cat. Other local mechanics have used the same part with success I was told by the supplier. I'll post back with results Thanks! Link to comment Share on other sites More sharing options...
MrWinkey Posted January 28, 2007 Report Share Posted January 28, 2007 New OEM o2's didn't have tool to pop out ECM but I shorted the batt terminals together for about 10min and no luck. I even placed the rear 02 out of the direct stream (used an 18mm sparkplug anti-fouling bushing) to try and fool the ecm and no luck. I'll have volvo attempt adaptive reset this week but I'm leaning torwards the aftermarket cat. Other local mechanics have used the same part with success I was told by the supplier. I'll post back with results Thanks!After hearing that I believe it's the cat? :huh: Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted January 29, 2007 Report Share Posted January 29, 2007 I have seen an aftermarket cat cause problems on these cars now that I think about it. Link to comment Share on other sites More sharing options...
smokin' T5M Posted January 29, 2007 Report Share Posted January 29, 2007 If you really have no leaks in the syst then I agree with the CAT. Is this a turbo? How many miles. I have had a car with a similar problem that ended up needing valve seals. THey were caked up pretty bad and there was oil leaking into the valves causing a poor reading at the O2's. But the light also never came on that quick. You said you don't have a short to the wires correct? Hope everything works out Link to comment Share on other sites More sharing options...
garbergtsi Posted January 29, 2007 Report Share Posted January 29, 2007 +1, you just wasted $$ on an aftermarket cat. Link to comment Share on other sites More sharing options...
necvolvo Posted January 30, 2007 Author Report Share Posted January 30, 2007 If you really have no leaks in the syst then I agree with the CAT. Is this a turbo? How many miles. I have had a car with a similar problem that ended up needing valve seals. THey were caked up pretty bad and there was oil leaking into the valves causing a poor reading at the O2's. But the light also never came on that quick. You said you don't have a short to the wires correct? Hope everything works outThe car runs Great..no oil consumption and good compression. Takes about 18 miles for a drive cycle and it instantly comes on when the cat readiness is complete as shown on my snappy scanner Link to comment Share on other sites More sharing options...
necvolvo Posted January 30, 2007 Author Report Share Posted January 30, 2007 +1, you just wasted $$ on an aftermarket cat.I agree under the gun to get it down the road. Left the old one at the shop and was planning to re-install it but if you leave anything worth 10 cents or more for 5 minutes it tends to dissapear as mine did :angry: Link to comment Share on other sites More sharing options...
Guest alexa Posted January 31, 2007 Report Share Posted January 31, 2007 免费铃声 手机铃声下载铃声 铃声下载 手机铃声 铃声 手机铃声 手机图片手机彩铃 mp3铃声 免费点歌手机铃声 手机铃声 铃声下载 手机图片 手机铃声下载 彩信图片 手机图片 手机铃声 手机铃声图片下载 号码 不怕不怕 香水有毒 千里之外 秋天不回来 月亮之上 求佛 隐形的翅膀大城小爱 一万个理由 曹操 认真的雪 那一夜 QQ爱 死了都要爱 不要再来伤害我 我的果汁分你一半老公老公我爱你 老婆老婆我爱你 不怕不怕 隐形的翅膀 求佛 死了都要爱 桃花朵朵开 亚洲交友中心供求信息亚洲交友联盟 秋天不回来 月亮之上 QQ爱 号码 香水有毒 认真的雪 爱哭鬼 梁祝亚洲交友中心 河北交友网 免费交友 亚洲交友网 中国交友中心 交友网站 交友 亚洲交友中心求佛 香水有毒 香水有毒 月亮之上 不怕不怕 秋天不回来 大城小爱 离歌 一万个理由 QQ爱千里之外 秋天不回来 不怕不怕 求佛 发如雪 隐形的翅膀 香水有毒 月亮之上 亚洲交友中心亚洲交友中心亚洲交友中心大城小爱 一万个理由 曹操 认真的雪 不要再来伤害我 死了都要爱 号码 QQ爱手机视频 手机软件 手机游戏下载 手机小说 手机视频 免费点歌 我的果汁分你一半 手机游戏 月亮之上DJ 铃声下载千里之外 香水有毒 求佛 我要为你戒烟 月亮之上 隐形的翅膀 菊花台 死了都要爱 不怕不怕 香水有毒秋天不回来 大喜宙 大城小爱 不要再来伤害我 那一夜 号码 QQ爱 认真的雪 离歌 手机铃声下载和弦铃声mp3铃声手机图片 手机游戏下载 激情电影 大喜宙 我的果汁分你一半 不怕不怕 大城小爱 月亮之上求佛 隐形的翅膀 千里之外 月亮之上 秋天不回来 菊花台 我要为你戒烟 发如雪 手机小说 手机软件 免费点歌免费点歌 免费点歌 手机图片 铃声 铃声 MP3铃声下载 铃声下载 MP3铃声下载 手机铃声下载 彩信铃声大城小爱 千里之外 香水有毒 求佛 秋天不回来 不怕不怕 千里之外 香水有毒 求佛 免费手机铃声 铃声 手机彩铃 手机铃声 搞笑视频 手机视频 手机游戏 手机游戏下载 手机游戏下载 短信 祝福短信 免费点歌美女写真美女图片手机彩铃 月亮之上 秋天不回来 香水有毒 求佛 数码相机 千里之外 菊花台 隐形的翅膀手机彩铃手机铃声下载和弦铃声原音铃声MP3铃声搞笑铃声手机彩信图片手机游戏下载手机视频下载手机图片 不怕不怕铃声 香水有毒 彩信图片 免费点歌 MP3铃声彩信图片彩铃下载手机彩铃手机铃声免费下载 Link to comment Share on other sites More sharing options...
Sinbad Posted January 31, 2007 Report Share Posted January 31, 2007 Alexa's cat is broken too. Link to comment Share on other sites More sharing options...
terrytcl Posted January 31, 2007 Report Share Posted January 31, 2007 I have the dreaded P0442 CEL too.Done everything short of changing the cat.Someone on the V70R forum mentioned that it may not be a problem with the cat, rather... a problem with an exhaust leak.I would check around all of the gaskets upstream from the primary oxygen sensor. depending on the sensitivity of the signals that the ECU is looking for... it may be a problem (the exhaust leak), if measurements among the MAF, primary o2, and secondary o2 sensors are being compared. My CEL comes back as soon as the drive cycle is complete too. Before coughing up the cash for a new cat, i would check your exhaust gaskets (manifold, turbo, downpipe) and all the emission related vacuum lines. Link to comment Share on other sites More sharing options...
necvolvo Posted February 1, 2007 Author Report Share Posted February 1, 2007 I have the dreaded P0442 CEL too.Done everything short of changing the cat.Someone on the V70R forum mentioned that it may not be a problem with the cat, rather... a problem with an exhaust leak.I would check around all of the gaskets upstream from the primary oxygen sensor. depending on the sensitivity of the signals that the ECU is looking for... it may be a problem (the exhaust leak), if measurements among the MAF, primary o2, and secondary o2 sensors are being compared. My CEL comes back as soon as the drive cycle is complete too. Before coughing up the cash for a new cat, i would check your exhaust gaskets (manifold, turbo, downpipe) and all the emission related vacuum lines.Did every test by the the book..exhaust, air leaks, smoked the car, comp temp, fuel press test, and today broke down and dropped $750 (my cost) for the cat from volvo, low and behold the light stays off and readiness is fine!!!! Should have known that the $250 aftermarket was a piece of junk Why they bother making some thing that will not work is beyond me, the fitment was fine but the performace stunk!. On to the Next horror show...Thanks all Link to comment Share on other sites More sharing options...
garbergtsi Posted February 1, 2007 Report Share Posted February 1, 2007 Should have known that the $250 aftermarket was a piece of junk Why they bother making some thing that will not work is beyond meBecause there is always cheap, clueless people out there that will buy the crap. I see it all the time! Link to comment Share on other sites More sharing options...
