echristodo Posted February 6, 2007 Report Share Posted February 6, 2007 If you guys want I can run your VIN through Volvo's Warranty/Recall portal to see what has been done to your car or what you are eligible for as far as recalls/warranty work... Post VIN in this thread and I will reply with pasted results. Link to comment Share on other sites More sharing options...
Stormtrooper1 Posted February 6, 2007 Report Share Posted February 6, 2007 YV1LW5242W2444674Thanks- Link to comment Share on other sites More sharing options...
JAGMAN Posted February 6, 2007 Report Share Posted February 6, 2007 YV1SJ52Y942418129Thanks, you can reply by email if it will save space in the thread. Link to comment Share on other sites More sharing options...
drin850 Posted February 6, 2007 Report Share Posted February 6, 2007 YV1LS500XT2317162Thanks!!! Link to comment Share on other sites More sharing options...
Zappo Posted February 6, 2007 Report Share Posted February 6, 2007 I know I still have the fuel tank recall to be done on mine. Just haven't been motivated to take it in yet. Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 YV1LW5242W2444674Thanks-RECALL CAMPAIGN 101 Credited 9/28/01 35233 Bulb holder indicato 08628377-7 BULB SOCKET, ASSEM 49385 3639 Gallo Motor Center Corp SERVICE CAMPAIGN101A Credited 9/28/01 36921 Headlamp wiper stop 08628222-5 STOP LUG 49385 3639 Gallo Motor Center Corp SERVICE CAMPAIGN101B Credited 9/28/01 37931 Adapter cable headla 00274261-7 BULB KIT 49385 3639 Gallo Motor Center Corp WARRANTY Credited 6/24/02 88412 Seat belt buckle fro 09167651-0 BELT CATCH 64932 3639 Gallo Motor Center Corp WARRANTY Credited 10/08/01 51216 Brake discs rear x2 00272248-6 BRAKE DISC KIT 50298 3639 Gallo Motor Center Corp WARRANTY Credited 7/03/01 36478 Door module replace, 08637142-4 SWITCH 44252 3639 Gallo Motor Center Corp WARRANTY Credited 4/23/01 25427 Air pump non-return 09125623-0 CHECK VALVE 40385 3639 Gallo Motor Center Corp WARRANTY Credited 8/10/00 28463 Engine control modul 34239 3639 Gallo Motor Center Corp NOTHING OUTSTANDINGYV1SJ52Y942418129Thanks, you can reply by email if it will save space in the thread.PRE-DELIVERY Credited 1/24/04 01717 CPS - Customer Prepa 10 3261 INSKIP VOLVO MAINTENANCE Credited 7/14/05 17612 Maintenance service 01275810-8 FILTER INSERT 32047 7621 PHILLIPS VOLVO MAINTENANCE Credited 12/28/04 17608 Maintenance service 01275810-8 FILTER INSERT 22445 3634 DALZELL VOLVO MAINTENANCE Credited 8/26/04 17605 Maintenance service 01275810-8 FILTER INSERT 15446 3261 INSKIP VOLVO MAINTENANCE Credited 6/05/04 17602 Maintenance service 01275810-8 FILTER INSERT 8155 3261 INSKIP VOLVO WARRANTY Credited 11/27/06 76104 Shock absorber rear 30683704-8 SHOCK ABSORBER 49488 7621 PHILLIPS VOLVO WARRANTY Credited 11/08/06 76104 Shock absorber rear 30683704-8 SHOCK ABSORBER 48762 7621 PHILLIPS VOLVO WARRANTY Credited 10/10/06 46664 Rubber gaiter outer 00272440-9 BELLOWS KIT 48048 7621 PHILLIPS VOLVO WARRANTY Credited 4/03/06 64218 Steering gear rem-in 08603473-3 STEERING BOX, EXCH 43233 7621 PHILLIPS VOLVO WARRANTY Credited 4/03/06 64205 Roller limiter contr 30714977-3 ROLLER 43233 7621 PHILLIPS VOLVO WARRANTY Credited 11/01/05 65268 Bushing, inner link 30748437-8 BUSHING 36692 7621 PHILLIPS VOLVO WARRANTY Credited 11/01/05 35203 Headlamp assembly x1 30698824-7 HEADLAMP, RIGHT 36692 7621 PHILLIPS VOLVO WARRANTY Credited 10/14/05 25293 Crossmember rear exh 30676687-4 SERVICE KIT 36112 7621 PHILLIPS VOLVO WARRANTY Credited 7/14/05 35203 Headlamp assembly x1 30698823-9 HEADLAMP, LEFT 32047 7621 PHILLIPS VOLVO WARRANTY Credited 7/14/05 37206 Control module / rel 30657629-9 ELECTRONICS BOX 32047 7621 PHILLIPS VOLVO WARRANTY Credited 12/28/04 76102 Shock absorber front 30683703-0 SHOCK ABSORBER 22445 3634 DALZELL VOLVO WARRANTY Credited 6/28/04 46630 Drive shaft front le 00272440-9 BELLOWS KIT 10011 3261 INSKIP VOLVO WARRANTY Credited 4/22/04 28462 Engine control modul 4351 3261 INSKIP VOLVO WARRANTY Credited 4/22/04 36004 Software control mod 30677020-7 DIM UPGRADE 4351 3261 INSKIP VOLVO WARRANTY Credited 1/21/04 38319 Vehicle speed sensor 1 2701 FOREIGN AUTO PREPARATION SERVYV1LS500XT2317162Thanks!!!RECALL CAMP 112 INCOMPLETE ERVICE CAMP 140 INCOMPLETE *take your shit in* Link to comment Share on other sites More sharing options...
mbaker Posted February 7, 2007 Report Share Posted February 7, 2007 yv1ls5812s2247507thanksmike Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 yv1ls5812s2247507thanksmikeRECALL CAMP 139 INCOMPLETE *take your shit in* Link to comment Share on other sites More sharing options...
bagodoosh Posted February 7, 2007 Report Share Posted February 7, 2007 YV1LW5342W2372678thank you. Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 YV1LW5342W2372678thank you.RECALL CAMPAIGN 101 Credited 4/12/04 35233 Bulb holder indicato 08628377-7 BULB SOCKET, ASSEM 98920 7309 KEYSTONE MOTORS RECALL CAMPAIGN 96 Credited 11/15/99 88191 Airbag passenger sid 00274147-8 KIT 35368 3341 MARTIN's MANHATTAN SERVICE CAMPAIGN 83C Credited 4/12/04 23910 Action if MIL lamp l 00948211-8 CABLE TIE 98920 7309 KEYSTONE MOTORS SERVICE CAMPAIGN101A Credited 4/12/04 36921 Headlamp wiper stop 08628222-5 STOP LUG 98920 7309 KEYSTONE MOTORS SERVICE CAMPAIGN101B Credited 4/12/04 37931 Adapter cable headla 00274261-7 BULB KIT 98920 7309 KEYSTONE MOTORS SERVICE CAMPAIGN 83 Credited 4/12/04 87992 Oil/refrigerant leak 98920 7309 KEYSTONE MOTORS WARRANTY Credited 4/24/00 39378 Radio cassette repla 08103944-8 EXCH. SC-816 40874 3341 MARTIN's MANHATTAN WARRANTY Credited 2/03/00 64108 Steering wheel lock 09157056-4 LOCK CYLINDER SET 38163 3341 MARTIN's MANHATTAN WARRANTY Credited 11/15/99 83414 Lock unit front side 09203903-1 LOCK, LEFT 35368 3341 MARTIN's MANHATTAN WARRANTY Credited 11/15/99 36317 Non-return valve win 09178895-0 DELIVERY VALVE 35368 3341 MARTIN's MANHATTAN WARRANTY Credited 11/15/99 35131 Bulb side indicator 09178939-6 LAMP SOCKET 35368 3341 MARTIN's MANHATTAN WARRANTY Credited 11/15/99 84159 Trim mouldings, misc 09187646-6 GUIDE, LEFT 35368 3341 MARTIN's MANHATTAN *NOTHING OUTSTANDING* Link to comment Share on other sites More sharing options...
mbaker Posted February 7, 2007 Report Share Posted February 7, 2007 RECALL CAMP 139 INCOMPLETE *take your shit in*what is that?mike Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 what is that?mikeVOLVO CAR CORPORATIONNHTSA Recall No. 04V368/Volvo Recall No. 139Vehicles: 1994-97 Volvo 850 manufactured from July 1993 through December 1996.Population: 105,000 passenger cars originally sold or currently registered in the hot weather states of Alabama, Arkansas, Arizona, California, Florida, Georgia, Hawaii, Louisiana, Mississippi, Nevada, New Mexico, North Carolina, Oklahoma, South Carolina, Tennessee, Texas, and Utah.Problem: After prolonged exposure to heat, the fuel tank may seep or leak fuel at the points where the heat shield is attached. Fuel leakage could result in a fire.Remedy: Dealers will inspect the fuel tank and replace it if any evidence of fuel seepage or leakage is found. All vehicles will receive new reinforcement bushings at the heat shield attachment points to prevent future leaks. 121,500 passenger cars in the other 33 states and the District of Columbia will be covered by a service campaign. Owners may contact Volvo at 1-800-458-1552. Link to comment Share on other sites More sharing options...
Greenchunks Posted February 7, 2007 Report Share Posted February 7, 2007 YV1LS5346W143 Link to comment Share on other sites More sharing options...
Dmsee Posted February 7, 2007 Report Share Posted February 7, 2007 I was told by the dealer that if your car was in accident they wont do any recalls as it out of warranty? Is this true? Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 I was told by the dealer that if your car was in accident they wont do any recalls as it out of warranty? Is this true?Meh, it all depends. A rebuilt title does cancel any warranties you have on the car, but it should not affect warranty work, depending on what it is.YV1LS5346W143I need all 16 digits of your VIN, not just the first 13!!!! Link to comment Share on other sites More sharing options...
