echristodo Posted February 7, 2007 Report Share Posted February 7, 2007 If you guys want I can run your VIN through Volvo's Warranty/Recall portal to see what has been done to your car, or what you are eligible for as far as recalls/warranty work... If you have not had that ETM upgrade (R155) this will let you know.Post VIN in this thread and I will reply with pasted results. Link to comment Share on other sites More sharing options...
Guest Guest Posted February 7, 2007 Report Share Posted February 7, 2007 Thanks YV1CN59H841061918 Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 Thanks YV1CN59H841061918 RECALL CAMPAIGN 157 Credited 10/25/06 64338 Steering arm outer 2 30760806-7 BALL JOINT KIT 68647 7223 MARGATE VOLVO RECALL CAMPAIGN 156 Credited 10/25/06 36391 2 wiper arms, replac 08620839-4 WIPER ARM 68647 7223 MARGATE VOLVO CAMPAIGN Swivel for Credited 12/08/05 36694 Key ring (KIR) insta 30710336-6 SWIVEL 49916 7223 MARGATE VOLVO CAMPAIGN Software up Credited 12/08/05 36004 Software control mod 30677038-9 TOTAL UPGRADE CAN 49916 7223 MARGATE VOLVO CAMPAIGN Floor vent Credited 12/08/05 99094 Bracket side panel d 30676653-6 PLASTIC FOAM 49916 7223 MARGATE VOLVO CAMPAIGN Tailgate la Credited 12/08/05 99096 Clamp lock tailgate 00983706-3 CABLE TIE 49916 7223 MARGATE PRE-DELIVERY Credited 9/30/03 01717 CPS - Customer Prepa 11 7222 GOLD COAST VOLVO ******TERMI MAINTENANCE Credited 4/13/04 17602 Maintenance service 01275810-8 FILTER INSERT 8685 7222 GOLD COAST VOLVO ******TERMI WARRANTY Credited 12/08/05 25121 Electronic throttle 49916 7223 MARGATE VOLVO WARRANTY Credited 11/02/05 23819 Pressure regulator p 48053 7223 MARGATE VOLVO Link to comment Share on other sites More sharing options...
garbergtsi Posted February 7, 2007 Report Share Posted February 7, 2007 Or you could just go here and check:http://www.ford.com/en/vehicles/owners/rec...fault.htm#volvo Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 Or you could just go here and check:http://www.ford.com/en/vehicles/owners/rec...fault.htm#volvonone of the information listed below came up when i ran his vin through your link.RECALL CAMPAIGN 157 Credited 10/25/06 64338 Steering arm outer 2 30760806-7 BALL JOINT KIT 68647 7223 MARGATE VOLVO RECALL CAMPAIGN 156 Credited 10/25/06 36391 2 wiper arms, replac 08620839-4 WIPER ARM 68647 7223 MARGATE VOLVO CAMPAIGN Swivel for Credited 12/08/05 36694 Key ring (KIR) insta 30710336-6 SWIVEL 49916 7223 MARGATE VOLVO CAMPAIGN Software up Credited 12/08/05 36004 Software control mod 30677038-9 TOTAL UPGRADE CAN 49916 7223 MARGATE VOLVO CAMPAIGN Floor vent Credited 12/08/05 99094 Bracket side panel d 30676653-6 PLASTIC FOAM 49916 7223 MARGATE VOLVO CAMPAIGN Tailgate la Credited 12/08/05 99096 Clamp lock tailgate 00983706-3 CABLE TIE 49916 7223 MARGATE PRE-DELIVERY Credited 9/30/03 01717 CPS - Customer Prepa 11 7222 GOLD COAST VOLVO ******TERMI MAINTENANCE Credited 4/13/04 17602 Maintenance service 01275810-8 FILTER INSERT 8685 7222 GOLD COAST VOLVO ******TERMI WARRANTY Credited 12/08/05 25121 Electronic throttle 49916 7223 MARGATE VOLVO WARRANTY Credited 11/02/05 23819 Pressure regulator p 48053 7223 MARGATE VOLVO Link to comment Share on other sites More sharing options...
Jarhead Posted February 7, 2007 Report Share Posted February 7, 2007 yv1lw56d9x2554133 Link to comment Share on other sites More sharing options...
Guest Guest Posted February 7, 2007 Report Share Posted February 7, 2007 credited means it has been done? Link to comment Share on other sites More sharing options...
echristodo Posted February 7, 2007 Author Report Share Posted February 7, 2007 yv1lw56d9x2554133SERVICE CAMP 155 INCOMPLETE RECALL CAMP 142 Credited 5/11/05 36496 Control panel, light 08601773-8 LIGHT SWITCH 88665 5379 POWER VOLVO IRVINE RECALL CAMPAIGN 101 Credited 7/12/01 35233 Bulb holder indicato 08628377-7 BULB SOCKET, ASSEM 39103 5379 POWER VOLVO IRVINE SERVICE CAMPAIGN101B Credited 7/12/01 37931 Adapter cable headla 00274261-7 BULB KIT 39103 5379 POWER VOLVO IRVINE MAINTENANCE Credited 2/28/06 25128 Electronic throttle 08644347-0 THROTTLE BODY 98940 5379 POWER VOLVO IRVINE WARRANTY Credited 6/26/02 88267 Glove compartment re 09150763-2 GLOVE COMPARTMENT 49966 5379 POWER VOLVO WARRANTY Credited 6/20/02 87304 Heat exchanger repla 09144221-0 HEAT EXCHANGER 49733 5379 POWER VOLVO IRVINE WARRANTY Credited 6/10/02 35112 Bulb tail lamp repla 00965826-1 BULB 49315 5379 POWER VOLVO IRVINE WARRANTY Credited 3/13/02 88272 Cup holder tunnel tr 09499406-8 CUP HOLDER 46726 5379 POWER VOLVO IRVINE WARRANTY Credited 10/31/01 87306 Blower fan motor rep 09171429-5 FAN MOTOR 43103 5379 POWER VOLVO IRVINE WARRANTY Credited 4/30/01 03515 Tech Net 35-09 Head 00981465-8 BULB 36125 5379 POWER VOLVO IRVINE WARRANTY Credited 2/02/01 59302 Anti-lock Brake Syst 08619544-3 CONTROL UNIT 33858 5379 POWER VOLVO IRVINE WARRANTY Credited 1/08/01 21702 Gasket oil pan repla 01161059-9 CHEMICAL GASKET 33120 5379 POWER VOLVO IRVINE WARRANTY Credited 4/20/00 03514 PILOT: Turn Signal 09178939-6 LAMP SOCKET 21674 5379 POWER VOLVO IRVINE WARRANTY Credited 3/13/00 35122 Headlight bulb x 1, 00980556-5 BULB 19690 5379 POWER VOLVO IRVINE *you need to have the software to your ETM upgraded* credited means it has been done?correct sir. Link to comment Share on other sites More sharing options...
TheCapn Posted February 7, 2007 Report Share Posted February 7, 2007 YV1LW55A0X2620334Thanks, Link to comment Share on other sites More sharing options...
Guest Guest_buddyiramae_* Posted February 7, 2007 Report Share Posted February 7, 2007 If you guys want I can run your VIN through Volvo's Warranty/Recall portal to see what has been done to your car, or what you are eligible for as far as recalls/warranty work... If you have not had that ETM upgrade (R155) this will let you know.Post VIN in this thread and I will reply with pasted results.My 99 C70 convertible VIN isyv1nc56d2xj003212Thanks in advance.Michael. Link to comment Share on other sites More sharing options...
bes4420 Posted February 7, 2007 Report Share Posted February 7, 2007 Great. If you could run my vin, I'd be greatful.YV1TS90D5X1040605Bill Link to comment Share on other sites More sharing options...
garbergtsi Posted February 7, 2007 Report Share Posted February 7, 2007 the link i provided gives open recalls, but it doesnt list warranty work or recalls that HAVE already been done. If you put in the VIN, it tells you what recalls NEED to be done. Link to comment Share on other sites More sharing options...
Adam Franke Posted February 7, 2007 Report Share Posted February 7, 2007 YV1LS55A4X2605492 Link to comment Share on other sites More sharing options...
Guest Guest_jarhead_* Posted February 7, 2007 Report Share Posted February 7, 2007 Thanks I have an apointment for the 10th.SERVICE CAMP 155 INCOMPLETE RECALL CAMP 142 Credited 5/11/05 36496 Control panel, light 08601773-8 LIGHT SWITCH 88665 5379 POWER VOLVO IRVINE RECALL CAMPAIGN 101 Credited 7/12/01 35233 Bulb holder indicato 08628377-7 BULB SOCKET, ASSEM 39103 5379 POWER VOLVO IRVINE SERVICE CAMPAIGN101B Credited 7/12/01 37931 Adapter cable headla 00274261-7 BULB KIT 39103 5379 POWER VOLVO IRVINE MAINTENANCE Credited 2/28/06 25128 Electronic throttle 08644347-0 THROTTLE BODY 98940 5379 POWER VOLVO IRVINE WARRANTY Credited 6/26/02 88267 Glove compartment re 09150763-2 GLOVE COMPARTMENT 49966 5379 POWER VOLVO WARRANTY Credited 6/20/02 87304 Heat exchanger repla 09144221-0 HEAT EXCHANGER 49733 5379 POWER VOLVO IRVINE WARRANTY Credited 6/10/02 35112 Bulb tail lamp repla 00965826-1 BULB 49315 5379 POWER VOLVO IRVINE WARRANTY Credited 3/13/02 88272 Cup holder tunnel tr 09499406-8 CUP HOLDER 46726 5379 POWER VOLVO IRVINE WARRANTY Credited 10/31/01 87306 Blower fan motor rep 09171429-5 FAN MOTOR 43103 5379 POWER VOLVO IRVINE WARRANTY Credited 4/30/01 03515 Tech Net 35-09 Head 00981465-8 BULB 36125 5379 POWER VOLVO IRVINE WARRANTY Credited 2/02/01 59302 Anti-lock Brake Syst 08619544-3 CONTROL UNIT 33858 5379 POWER VOLVO IRVINE WARRANTY Credited 1/08/01 21702 Gasket oil pan repla 01161059-9 CHEMICAL GASKET 33120 5379 POWER VOLVO IRVINE WARRANTY Credited 4/20/00 03514 PILOT: Turn Signal 09178939-6 LAMP SOCKET 21674 5379 POWER VOLVO IRVINE WARRANTY Credited 3/13/00 35122 Headlight bulb x 1, 00980556-5 BULB 19690 5379 POWER VOLVO IRVINE *you need to have the software to your ETM upgraded* correct sir. Link to comment Share on other sites More sharing options...
bes4420 Posted February 7, 2007 Report Share Posted February 7, 2007 Great. If you could run my vin, I'd be greatful.YV1TS90D5X1040605BillI meant I'd be grateful...not greatful. Damned dictionary Link to comment Share on other sites More sharing options...
