Greg's Project Daily Driver
Yeah... I'm not too worried, I am running an FMIC with waterinjection. Might be going further with some more cooling effort depending on how things look at my planned max psi... Only time will tell. I have alot of time to wait too :(
You didnt' have a tune? For some reason I always thought you had either RICA or IPD?
nope.
Just got back from the machine shop. Feel much better w/ these guys.. The shop foreman took one look at one of the pistons and saw it had a cracked ring land.. Also discussed tolerances and which pistons to go and we all decided that the OS1 is the best way to go.
  • Downvote 1
You're getting a valve job, but not porting the head? Why not have it done while it's apart? should only be an extra 4 bills
Because I honeslty don't have the money for it right now. It's no big deal to pull the head.
is that a forge wastegate? how much for that and do they make one that will mount to a 16T? Do you have to do any mods to mount it to the 19T?
it will bolt up right to a 16T after you drill out the holes for the wastegate tomount to bracket. You have to use a different rod to mount it to the 19T. The rods on the wastegate are interchangeable. It's a Forge FMAC048 wastegate actuator for a T3/T4/T35 and it's adjustable. :) also, on the 19T, the wastegate will hit the CBV housing if you don't file some material out, it's an easy fix w/ a round and flat bastard file.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
