Slonik Posted March 29, 2007 Report Share Posted March 29, 2007 Well, after this R pretty much ATE the front tires (Michelin MXV4 Plus) I put Pilot Sports all around and, well, I don't want it to eat these. Would realigning the front to all factory spec but with -1 degree camber help? Car is bone stock with 55k miles. Link to comment Share on other sites More sharing options...
steve s Posted March 29, 2007 Report Share Posted March 29, 2007 is it off? u may get some funky feathering if u toe-in and caster are off. unless u go crazy, camber would more likely affect how badly u eat up the outside edges given how these cars like to understeer...the last few tires in the pilot sport category i tried last only about 10k (if not less) on the front if u don't rotate.. granted, it's on fwd and not like ur awd.. Link to comment Share on other sites More sharing options...
Johann Posted March 29, 2007 Report Share Posted March 29, 2007 Stock alignment with a -0.3 to -0.5 camber should be OK. Link to comment Share on other sites More sharing options...
Slonik Posted March 29, 2007 Author Report Share Posted March 29, 2007 is it off? u may get some funky feathering if u toe-in and caster are off. unless u go crazy, camber would more likely affect how badly u eat up the outside edges given how these cars like to understeer...the last few tires in the pilot sport category i tried last only about 10k (if not less) on the front if u don't rotate.. granted, it's on fwd and not like ur awd..Oh... I'm going to rotate the crap out of these guys. Link to comment Share on other sites More sharing options...
blkaplan Posted March 29, 2007 Report Share Posted March 29, 2007 If you are wearing the outside edge quickly, add more negative camber. I run -2.5 on my street car to keep my tires from eating the shoulders Link to comment Share on other sites More sharing options...
towerymt Posted March 29, 2007 Report Share Posted March 29, 2007 What part was "eaten" the most? Too much toe-in, or agressive driving with minimal negative camber (or positive) can wear the outside edges. Too much toe-out can quickly kill the inside edges. Rapid edge wear on both edges or rapid center wear would likely indicate improper tire pressure. If the tread blocks wear unevenly across the individual block of tread (feathered edges), it's probably a suspension/steering wear issue. Link to comment Share on other sites More sharing options...
