JHEIII874T5M Posted September 10, 2007 Report Share Posted September 10, 2007 B) Looking good, Raf. Link to comment Share on other sites More sharing options...
larryo108 Posted September 10, 2007 Report Share Posted September 10, 2007 Raf. Fucking amazing. One of my favorite cars on this site. Are those HRE wheels? Man you do nothing half-ass. Fan-fucking-tastic.On a side note, thanks for all the help with my Volvo and for the help with the future car. Raf is an OG and one of the most helpful and coolest cats on this site. The rest of you know who you are. I ask you all questions all the time. Link to comment Share on other sites More sharing options...
brettfessler Posted September 10, 2007 Report Share Posted September 10, 2007 omg Link to comment Share on other sites More sharing options...
caanglin Posted September 10, 2007 Report Share Posted September 10, 2007 F'n love it. Good job. Link to comment Share on other sites More sharing options...
Mesoam Posted September 10, 2007 Report Share Posted September 10, 2007 Raf where is your PCV plumbing going to? Noticed the long tube, running a catch can? Concerned at all about the turbo hitting the mount at WOT? Link to comment Share on other sites More sharing options...
Mike H. Posted September 10, 2007 Report Share Posted September 10, 2007 I refinshed the calipers myselfRaf - Painted or powercoated? If painted, what kind? Do you have to rebuild the calipers when refinishing or can you just tape them off?Nevermind, read a few pages back that you you were going to powdercoat them. Would you be willing to help a fellow member out and blast a caliper? Link to comment Share on other sites More sharing options...
Carbon_R Posted September 10, 2007 Author Report Share Posted September 10, 2007 Raf - Painted or powercoated? If painted, what kind? Do you have to rebuild the calipers when refinishing or can you just tape them off?Nevermind, read a few pages back that you you were going to powdercoat them. Would you be willing to help a fellow member out and blast a caliper?Fo shizzle, send them to me. It's not a sand blaster but a glass bead blaster which is finer then sand but it strips everything PM me if you like..Raf Link to comment Share on other sites More sharing options...
NGB Posted September 10, 2007 Report Share Posted September 10, 2007 Fo shizzle, send them to me. It's not a sand blaster but a glass bead blaster which is finer then sand but it strips everything PM me if you like..RafYou did the powdercoating yourself? Link to comment Share on other sites More sharing options...
Carbon_R Posted September 10, 2007 Author Report Share Posted September 10, 2007 After I installed the tranny, I noticed that the RPM sensor wasn't flush with the manual tranny but it was with the auto.I looked at the gap between the auto flywheel and manual fywheel and they seem the same to my eyes. Can you guys check to see if you have a small gap like this on your car, everything lines up properly. I was thinking maybe this is the issue some people encounter with failed starts or hard starting issues?And I painted the subframe black Any thoughts on this subject?Raf Link to comment Share on other sites More sharing options...
Volvoteen Posted September 10, 2007 Report Share Posted September 10, 2007 What did you have to do to your ecu to switch the trannys out?? Link to comment Share on other sites More sharing options...
Carbon_R Posted September 10, 2007 Author Report Share Posted September 10, 2007 What did you have to do to your ecu to switch the trannys out??I have a 034 stand alone, the Ecu controls jack on my car, only a few inputs that are shared, RPM sensor, idle air control valve for cold starts and H2O temp sensor Raf Link to comment Share on other sites More sharing options...
BlackT5 Posted September 11, 2007 Report Share Posted September 11, 2007 I have a 034 stand alone, the Ecu controls jack on my car, only a few inputs that are shared, RPM sensor, idle air control valve for cold starts and H2O temp sensor RafI can see the stock ecu getting fed the rpm signal for the tach to work, but why the idle air signal? Doesn't the 034 have control of the motor for cold starts? Link to comment Share on other sites More sharing options...
prasamin Posted September 11, 2007 Report Share Posted September 11, 2007 mine had a gap, and the car wouldn't start.....Aaron figured it out, and made it flush, set it down a little lower, and we were GTG.It's not supposed to be at an angle like that, that'll throw the reading off. Link to comment Share on other sites More sharing options...
Mike H. Posted September 11, 2007 Report Share Posted September 11, 2007 Fo shizzle, send them to me. It's not a sand blaster but a glass bead blaster which is finer then sand but it strips everything PM me if you like..RafSweetness! Much Thanks. PM sent.Mike Link to comment Share on other sites More sharing options...
Carbon_R Posted September 11, 2007 Author Report Share Posted September 11, 2007 I can see the stock ecu getting fed the rpm signal for the tach to work, but why the idle air signal? Doesn't the 034 have control of the motor for cold starts?Yes it does Mark but the stock ECU does a fine job at it, so why mess with it.I have the connector for the 034 there, just not being used, I will address this prior to tuning.Rafmine had a gap, and the car wouldn't start.....Aaron figured it out, and made it flush, set it down a little lower, and we were GTG.It's not supposed to be at an angle like that, that'll throw the reading off.Thanks Pras, I will check it out if it doesn't fire up.by the way, Denny wants to chat with you in regards to your motor.Do you still have it?Raf Link to comment Share on other sites More sharing options...
