Mogatu'r Posted June 22, 2007 Report Share Posted June 22, 2007 Yes it's Denny. He's back in Houston, give him a shout.He's terminating the project for good a lot of his parts will be for sale soon, maybe all of the Houston crew can buy the parts or maybe you guys can convince him to keep it, if not, hit him up for the 034ECU Thanks for the props, I'm planing on visiting Denny soon.RafRaf,GUAO Simplemente!! Houston. mmm. Drop a line w/e. Hmm.. mebe I should talk to Denny about his car. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted June 22, 2007 Report Share Posted June 22, 2007 Yes it's Denny. He's back in Houston, give him a shout.He's terminating the project for good a lot of his parts will be for sale soon, maybe all of the Houston crew can buy the parts or maybe you guys can convince him to keep it, if not, hit him up for the 034ECU Thanks for the props, I'm planing on visiting Denny soon.Raf damn it where'd i put denny's number...parts parts parts :pulls out check book: O34 eh? GT30R...OOooOOoooOO his manual swap...lol hey TXC i think i just finished building my car :lol: Raf,GUAO Simplemente!! Houston. mmm. Drop a line w/e. Hmm.. mebe I should talk to Denny about his car.hey juan, u can have the yellow....i got dibs on the rest of the parts hahaha Link to comment Share on other sites More sharing options...
NW T5R Posted June 22, 2007 Report Share Posted June 22, 2007 Very Very nice build!!!! A couple questions. -What IC setup are you running?-A/C still in use?-Why do you have to use a prop rod on the carbon hood?-What size dp are you using?-What rear brakes did you go with?Lastly how is the 034 working within the climate span in your area. Winter low and summer high's? Link to comment Share on other sites More sharing options...
theForgottenone Posted June 22, 2007 Report Share Posted June 22, 2007 That's HOT :P Link to comment Share on other sites More sharing options...
JCviggen Posted June 22, 2007 Report Share Posted June 22, 2007 Awesome car man, and so clean always! I'm still enjoying that Turbonetics turbo of yours :D Link to comment Share on other sites More sharing options...
bigmay850 Posted June 22, 2007 Report Share Posted June 22, 2007 F-ing Amazing car!! Link to comment Share on other sites More sharing options...
Emiel Posted June 22, 2007 Report Share Posted June 22, 2007 Very, very nice car! :tup: Link to comment Share on other sites More sharing options...
Boomin850 Posted June 22, 2007 Report Share Posted June 22, 2007 Very Very nice build!!!! A couple questions. -What IC setup are you running?-A/C still in use?-Why do you have to use a prop rod on the carbon hood?-What size dp are you using?-What rear brakes did you go with?Lastly how is the 034 working within the climate span in your area. Winter low and summer high's?I can answer a few of these for Raf...Carbon hood doesn't use springs because it will litterally snap the hood in half. Btw...that prop you see is a damn BROOM HANDLE!!! Ghetto fab3'' dpS60R rear brakes (not installed yet) Link to comment Share on other sites More sharing options...
Carbon_R Posted June 23, 2007 Author Report Share Posted June 23, 2007 Very Very nice build!!!! A couple questions. -What IC setup are you running? The good ole "Atech IC" drop in.-A/C still in use? That's a big YES, blows cold air and everything else works just like the factory intended too!!-Why do you have to use a prop rod on the carbon hood? Looking into small gas shocks but I have to find the right one so it doesn't damage the hood, the getto broom stick is the only way to go for now..I had to remove the stock springs because they place too much pressure on the center of the hood and it will crack if left that way.-What size dp are you using? I modified my 3" BSR DP, used the 5 bolt flange from garrett and hacked the BSR cat off and placed a V-band on there for the ease install/removal.-What rear brakes did you go with? I have a stock slotted and I'm using Ferodo pads, same as front pads. I bought these thru Stoptech brakes. I have a set of R calipers with the R rotors going on soon. 034 is going to fab the brackets for me.Lastly how is the 034 working within the climate span in your area. Winter low and summer high's? Well my area in the summer get very toasty 100* and this past winter in the low 30's. The cold map needs some work but overall no problems, I'm very happy with the system and there customer service is top notch.Hope I answered your questions.Raf Link to comment Share on other sites More sharing options...
pwebb Posted June 24, 2007 Report Share Posted June 24, 2007 more info on your ignition! nicest 850. ever. hands down Link to comment Share on other sites More sharing options...
Carbon_R Posted June 24, 2007 Author Report Share Posted June 24, 2007 more info on your ignition! nicest 850. ever. hands downSince I opted for a stand alone, it didn't make sense to run a distributor/cap/rotor, I didn't want to encounter issues with hesitation or misfires while tuning plus the ECU can accommodate for a variety of coils and it can maximize the capability of any coil including target Dwell Time, Min. Dwell Time. I opted for 034 individual coil packs and the bracket was build to hold each individual coil.The coils are easily capable of over 100kV output. You could use it in multiples in direct fire applications (one per spark plug) or you can use it as single coil in distributor applications.The second option is the top mount coil for this kit, similar to the >MY99 Volvo's.RafAwesome car man, and so clean always! :lol:I'm still enjoying that Turbonetics turbo of yours hey, any new videos, how's the turbo holding out Raf Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted June 24, 2007 Report Share Posted June 24, 2007 034 is going to fab the brackets for me.Because I already have them in stock? Link to comment Share on other sites More sharing options...
Zulu Posted June 25, 2007 Report Share Posted June 25, 2007 Looking good...What's the part # on that headgasket, order it tomorrow prob...And those cams, what's their specs? Who do I contact to get a set...been trying to get cams. Crower is too much of a oh yeah! to deal with.Left a message on your phone a few days ago, wanted to know who you talked to at Wiseco & Cunningham...want to order my stuff in the next month. Link to comment Share on other sites More sharing options...
Boomin850 Posted June 25, 2007 Report Share Posted June 25, 2007 Looking good...What's the part # on that headgasket, order it tomorrow prob...And those cams, what's their specs? Who do I contact to get a set...been trying to get cams. Crower is too much of a oh yeah! to deal with.Left a message on your phone a few days ago, wanted to know who you talked to at Wiseco & Cunningham...want to order my stuff in the next month.PN of the head gasket is right there on it in that picture....30637066 Link to comment Share on other sites More sharing options...
Zulu Posted June 25, 2007 Report Share Posted June 25, 2007 PN of the head gasket is right there on it in that picture....30637066Oh cruised right over it... Link to comment Share on other sites More sharing options...
