Luther White Posted August 2, 2007 Report Share Posted August 2, 2007 CHANGE THE TEMP SENSOR Link to comment Share on other sites More sharing options...
Midimykeys Posted August 2, 2007 Author Report Share Posted August 2, 2007 thanks anyway Link to comment Share on other sites More sharing options...
Midimykeys Posted August 2, 2007 Author Report Share Posted August 2, 2007 CHANGE THE TEMP SENSORmy mechanic said there were many temp sensors. You mean the thermostat? Link to comment Share on other sites More sharing options...
Midimykeys Posted August 5, 2007 Author Report Share Posted August 5, 2007 that has to be the most ive seen anyone stretch a fuel problem... it similar to a bad temp sensor, i'm having similar issues and at times worse and i cant keep getting bad fuel over n over n over again... besides there are other teltale signs that its my temp sensor....i thought stock gap was .026.... .028 sounds largeWhat is a temp sensor, and where is it on the car? Link to comment Share on other sites More sharing options...
jdlc Posted August 6, 2007 Report Share Posted August 6, 2007 Temp sensor is CTS - coolant temperature sensor, it is located below the thermostat which is at the engine-end of the top cooling/radiator hose (this is true for 98 x70, it is likely the same location for your 850).When my CTS was failing, the symptom was engine running hot and poor mpg. If you should replace it, together with the thermostat, be sure not to round the torx bolts by using quality tools. Some here suggested replacing those bolts with new T-Stat housing bolts - part number is 986228. Link to comment Share on other sites More sharing options...
Guest Guest_Midimykeys_* Posted August 16, 2007 Report Share Posted August 16, 2007 Temp sensor is CTS - coolant temperature sensor, it is located below the thermostat which is at the engine-end of the top cooling/radiator hose (this is true for 98 x70, it is likely the same location for your 850).When my CTS was failing, the symptom was engine running hot and poor mpg. If you should replace it, together with the thermostat, be sure not to round the torx bolts by using quality tools. Some here suggested replacing those bolts with new T-Stat housing bolts - part number is 986228. Link to comment Share on other sites More sharing options...
Guest Guest_Midimykeys_* Posted August 16, 2007 Report Share Posted August 16, 2007 It was my head gasket. Fixing for $1100 or $1700 depending on what they need to do. Thanks for all your help ppl. :) Link to comment Share on other sites More sharing options...
