freeskier8585 Posted August 3, 2007 Report Share Posted August 3, 2007 Do i have to reset something? Link to comment Share on other sites More sharing options...
Mike_P Posted August 3, 2007 Report Share Posted August 3, 2007 Do i have to reset something?It should reset itself at about 15 mph as a self-test. If not check to see if the module is plugged in all the way, the connector can be difficult to seat Link to comment Share on other sites More sharing options...
Dmsee Posted August 3, 2007 Report Share Posted August 3, 2007 Are you sure it was a faulty module?? It might be the sensor too Link to comment Share on other sites More sharing options...
Guest Kieth Posted August 3, 2007 Report Share Posted August 3, 2007 I recently replaced the ABS Module on my 98 S70, the spedo was out and ABS/TRACS lights on. When I put in the new module the spedo worked but the lights would stay on.Turned out it was dirty ABS Sensors at the wheels. I cleaned them with wheel cleaner that was safe for abs and rubber parts. They weren't that dirty but had a good coating of road grime and grease on the tip. I also used the cleaner on the toothed gear behind the rotors that the sensors get thier signal from. Brakes have worked fine now for 6 months since. :) Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 4, 2007 Author Report Share Posted August 4, 2007 Ill have to give that a shot, hopefully soap and water works. Link to comment Share on other sites More sharing options...
Matchbox22 Posted August 4, 2007 Report Share Posted August 4, 2007 What about the old faulty ign. switch? Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 ???? Link to comment Share on other sites More sharing options...
Dmsee Posted August 5, 2007 Report Share Posted August 5, 2007 So you still have ABS and TRACS lit?If so did you check the codes before replacing the unit?Did you try to position the key on position II Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 checked no codes, it was intermittent for a while then has been on, figured it was bound to die or die soon with the suspension set up i have. Key pos II does nothing for the light. Link to comment Share on other sites More sharing options...
stm1up Posted August 5, 2007 Report Share Posted August 5, 2007 I had a similar situation in my 97 that threw no codes, the abs\tracs light was on and the speedo continued to work. The abs\tracs was intermittent to start with but eventually stayed on all the time. It ended up being the front left side wheel sensor that appeared to be fine looking at it but the wire had unseated itself but still inside the connector and just not making contact. Everything was fine after remaking the connection. Link to comment Share on other sites More sharing options...
flaco Posted August 5, 2007 Report Share Posted August 5, 2007 THIS fixed my problem:http://volvospeed.com/vs_forum/index.php?s...p;#entry1026029It seemed to happen more often with warm weather fyi... Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 ill check the wheel sensor in a few and if that is to no avail ill look at the box. Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 sensors were super dirty, but the light is still on. trying the fuse box attack now. Link to comment Share on other sites More sharing options...
Dmsee Posted August 5, 2007 Report Share Posted August 5, 2007 There should be codes if the light is still on. Get a scanner for ABS and scan Link to comment Share on other sites More sharing options...
stm1up Posted August 5, 2007 Report Share Posted August 5, 2007 Did you drive it once after you cleaned the wheel sensors? Link to comment Share on other sites More sharing options...
