freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 i have a scanner, no codes. I had the car on jacks and took it to 20 mph. I re soddered the the connection under the fuse box, does someone have a picture of the relay box under the driver kick panel, i took all the relays out to move the box and i have one little black relay that i cant seem to find a home for. Link to comment Share on other sites More sharing options...
Dmsee Posted August 5, 2007 Report Share Posted August 5, 2007 First. Go drive a car and brake couple of times.Second What scanner do you have? Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 i have an auterra, took the car out and stomped on it from 100, locked up all the tires in a firey cloud of tire destruction. Link to comment Share on other sites More sharing options...
Dmsee Posted August 5, 2007 Report Share Posted August 5, 2007 What did you say? Just to make sure. you read the ABS codes right? Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 5, 2007 Author Report Share Posted August 5, 2007 is that different than reading regular fault codes? Link to comment Share on other sites More sharing options...
stm1up Posted August 5, 2007 Report Share Posted August 5, 2007 What did you say? Just to make sure. you read the ABS codes right?I think he said there were no codes thrown, that he could then read had they been present. Link to comment Share on other sites More sharing options...
flaco Posted August 6, 2007 Report Share Posted August 6, 2007 any generic obd-ii scanner will not read ABS codes on an 850. if the light is on, you do have abs codes stored, but those can be read only with a volvo tool. time to give your dealer a visit...just to be sure, you re-soldered 4 wires total, right? Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 6, 2007 Author Report Share Posted August 6, 2007 well 4 wires total 2 wires in the black sleeve to the 2 wires that were wound. Link to comment Share on other sites More sharing options...
Dmsee Posted August 6, 2007 Report Share Posted August 6, 2007 if the light is on, you do have abs codes stored, but those can be read only with a volvo tool. time to give your dealer a visit...Thats what I have been saying. Go to dealership or Indy and tell them you need to read ABS codes.If there is a light then there is a code ;) Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 6, 2007 Author Report Share Posted August 6, 2007 gay, i hope there is a dealer in route to Va Link to comment Share on other sites More sharing options...
flaco Posted August 6, 2007 Report Share Posted August 6, 2007 well 4 wires total 2 wires in the black sleeve to the 2 wires that were wound.in that case you missed the other side sensor wiring. there are two thick black sleeved cables, each one containing 2 wires. the way you put it, there are 8 wires total, ie 4 different wire pairs that need to be soldered. Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 6, 2007 Author Report Share Posted August 6, 2007 looks like im digging back into that stuoid box again. Also i took all the relays off so that i could pull the fuse box up enough to sodder, i put them all back but one, that says "J" on it, like the big ones on the fuse box. Kinda dont know where it goes, could someone help me out. Link to comment Share on other sites More sharing options...
flaco Posted August 6, 2007 Report Share Posted August 6, 2007 now that you know what to look for... you can remove the top lid (4 torx) and see where the black wires enter the box, and carefully pull them until you get access to the original crimps. If youre lucky and they are not tangled, you wont have to lift the fuse block at all. I think if you look at the empty sockets on the fuse block, you should be able to figure where your missing relay goes. Most relays will only fit a unique location so.... Link to comment Share on other sites More sharing options...
freeskier8585 Posted August 6, 2007 Author Report Share Posted August 6, 2007 well most were color coded, this was the only one that wasnt, i have a few blanks, i guess ill just guess. Link to comment Share on other sites More sharing options...
S.Bunzel Posted August 6, 2007 Report Share Posted August 6, 2007 looks like im digging back into that stuoid box again. Also i took all the relays off so that i could pull the fuse box up enough to sodder, i put them all back but one, that says "J" on it, like the big ones on the fuse box. Kinda dont know where it goes, could someone help me out.Upper left corner but it is V70 2.5T from march 1998 <_< Link to comment Share on other sites More sharing options...
