sleddriver Posted August 18, 2007 Report Share Posted August 18, 2007 1998 V70 T5 138,500 miles. My first post here:After finally receiving all the parts for a timing belt change, I pull the covers, rotate the crankshaft around CW to line them up on top . . . and they're a bit off.So I looked down below at the crank pulley and it looks like the line on the engine is not between the two teeth with the slit on them, but in the next valley over?! And it's been like this for 6 years, when the indy shop last replaced the belt. Evidently my indy didn't do a final check . . . I can post photos if there's a way.Anyone seen this before they start?P.S. I measured it with a protractor and both intake & exhaust cams are off about 10 degrees, around one tooth, so that the marks on the camshafts pass the notch on the plastic cover as the crankshaft is rotated CW.My next Q: Can I rotate each camshaft backwards one tooth to realign them after taking the belt off?Thanks, Link to comment Share on other sites More sharing options...
pfeener Posted August 18, 2007 Report Share Posted August 18, 2007 Yes you can rotate the camshafts slightly in either direction without any problem. I would line up the crankshaft mark, remove the belt and line up the cams on their marks. Make sure you're looking at the correct mark on the block for the crank. I've seen people get confused with other marks. There's a good pic that's out here on the forum somewhere. I'll see if I can find it. Link to comment Share on other sites More sharing options...
pfeener Posted August 18, 2007 Report Share Posted August 18, 2007 Here's a post with a pic of the crank timing marks:http://volvospeed.com/vs_forum/index.php?s...3&hl=timing Link to comment Share on other sites More sharing options...
sleddriver Posted August 18, 2007 Author Report Share Posted August 18, 2007 Here's a post with a pic of the crank timing marks:http://volvospeed.com/vs_forum/index.php?s...3&hl=timingMuch thanks for the reply. I'm done for tonight. I thought to look at one of the intake cams through the Oil fill cap and noticed that the min. part of the cam lobe was in contact with the valve, thus it was closed. In this position, a tooth off isn't going to make much difference. I'll be doing everything I can get to: Water pump, both rollers, hydr. ten., TB, front crank seal and both cam seals. Then I won't have to worry about it for quite awhile. Link to comment Share on other sites More sharing options...
Vitor Posted August 18, 2007 Report Share Posted August 18, 2007 I thought I had some of those pics laying around. Link to comment Share on other sites More sharing options...
pfeener Posted August 18, 2007 Report Share Posted August 18, 2007 Great pics of the crank timing mark.Alvin, what do you think about pinning this thread? A lot of folks seem to have questions on the correct position of the crank pulley timing marks and these pics are the clearest I've seen. Link to comment Share on other sites More sharing options...
Vitor Posted August 18, 2007 Report Share Posted August 18, 2007 I have high resolution pics of the whole procedure.I will be doing that one day I don't have anything else to do. LOL. Link to comment Share on other sites More sharing options...
sleddriver Posted August 18, 2007 Author Report Share Posted August 18, 2007 Here's what the cams looked like with the crank sprocket in proper position. I colored in the index marks with yellow chalk. Link to comment Share on other sites More sharing options...
pfeener Posted August 19, 2007 Report Share Posted August 19, 2007 Yep, the last guy didn't do it right. I think you'll find it will run a whole lot stronger when you get it lined up correctly. Link to comment Share on other sites More sharing options...
AlvinL Posted August 19, 2007 Report Share Posted August 19, 2007 Great pics of the crank timing mark.Alvin, what do you think about pinning this thread? A lot of folks seem to have questions on the correct position of the crank pulley timing marks and these pics are the clearest I've seen.Good idea. I'll also remind everyone about Bay 13 (Rich Kelley's) write up on the timing belt replacement procedure. It too has nice pics. The write up can be found at Bay 13 - Maintenance & Repairs.850 S/V/C 70 Timing Belt Replacement Link to comment Share on other sites More sharing options...
