Post Your 60 Ft Times!
850 GLT
I'm curious as to what the best 60 ft time would be for our cars on street tires. If you have a manual tranny make sure you mention that. Also, explain what kind of tires, pressures, and technique you used if possible.
After 3 runs my best was a 2.306. I'm running 215/45/17 Goodyear GS-D3's. Judging from the video my friend took of one of my runs I'm getting a very small amount of tire spin. I brake torqued up to 2500ish and then floored it. I was running normal tire pressure, ~35 psi.
Alex
60ft Times:
1.95 ROB @ VMS C70 auto
1.957 BOOSTEDS60R
1.968 Volvospeed Admin
2.09 '95R
2.12 StickThatClutch S70 T5
2.130 Turbor850 S60R manual
2.157 UberV70 v70 awd manual
2.164 xcaliber912
2.175 JHEIII850Turbo 850 T5
2.183 Odell (his black 850)
2.197 Jesse850GLT (lpt)
2.206 ginkof S70 T5
2.208 850R//3KILLER 850r
2.234 ToxicLemonade 850 t5r
2.240 The Wifes Car s70
2.260 andrewclee 850r
2.270 Turbo Brick
2.271 850 glt
2.283 swdracr 850r
2.318 Melted
2.375 deafdano 850
2.428 Martin s70 t5 manual
2.445 Johann 850 manual
2.452 HPTJoe c70
2.495 Odell (bills old 850) manual
2.6XX Doug's Fabulous Launch
  • Replies 89
2.157 60'
Pirelli P-7000 215/35/19 34 PSI
V70 AWD 5-Speed Manual
I could probably do alot better but last time i went to the track (with new ecu) it was kinda cold and the track was slippery as hell. I think i could get a 2.0 on a hot day.
*edit* Just a note that this 60 foot time is BEFORE i got my new ECU *edit*
i feel good knowing that someone else (johann) with a well modded car still gets bad 60's like me...what wheels/tires you running johann?
Bridgestone Potenza S03 225/35-18 using several pressure settings.
2.208 60ft in my 850R
how bout 60's from non volvo?
my old car, 92 talon awd 1.790!
bandimere speedway 5800ft asl
you guys not getting wheel spin need to put your foot in it a little more at the tree! :D A bit of wheel spin is actually a good thing because it takes some of the load off your drivetrain and axles, as well the car fails to realize that the wheel is slipping (tracs-disengaged) and continues to increase rpm and boost pressure.
some of my highest traps and best 60's came from hard launching.
1 thing that should be noted here. A tenth less 60ft can turn into 2 tenths at the 1320 mark and
increased trap speeds!
2.270 on the stock 16" wheels.. can't remember what kind of tire it was though.
1989 Mustang, stock suspension with aftermarket upper and lower control arms, ET streets and skinnies: 1.677 60', Bradenton Motorsports Park.
A note about the Volvo.. my car only picked up ~19mph in the last 1/8th mile on its best run so far. It's a shame how weak these cars are up top.
